Whats the Best D16z6 Cam to Use..
Old May 18, 2010 | 11:13 PM
nihad's Avatar
Default Whats the Best D16z6 Cam to Use..
I am turboed and have been for a while now.. I have made 276whp and 251wtq on 12psi @3bar map.. My motor is all built and the head has springs and retainers and a zex59300.. You think i should keep the comp cam or get a bisi or delta or some thing else... I want to up the boost and make 400-450whp.. on e85 both tunes..
Old May 19, 2010 | 10:50 AM
nihad's Avatar
Default Re: Whats the Best D16z6 Cam to Use..
any know... 50views..
Old May 19, 2010 | 10:53 AM
Slo-mo's Avatar
The Bisi 3.6 cam has been doing pretty good from what i've seen. I think speedfactory did a test with it and it beat out all the other cams tested.
Old May 19, 2010 | 12:30 PM
NonovUrbizniz's Avatar
Loved
Most will tell you that headflow is really the stumbling block for z6's, I'd spend the money on porting after finding out that you can't make your goal with the current setup.
E85 and 59300 should be able to make 400hp. Maybe not 450 but again I think the stumbling block is more likely to be the head and not the cam.
Give a more detailed breakdown of your setup.
what rods/pistons
Injector CC's
management
Down pipe size
charge piping size
What turbo?
What manifold?
Old May 19, 2010 | 09:36 PM
nihad's Avatar
http://www.turbod16.com/viewtopic.ph...t=46709&hilit=
There you go... Man that 3.6 turbo cam is 400$.. I have a 59300 comp right now..
Old May 19, 2010 | 09:48 PM
nihad's Avatar
http://i39.tinypic.com/250jh1k.jpg
http://i48.tinypic.com/whcryx.jpg
http://i46.tinypic.com/106lu2c.jpg
http://i46.tinypic.com/24pklyr.jpg
http://i48.tinypic.com/zl3zh4.jpg
http://i46.tinypic.com/25f64wn.jpg
Old May 19, 2010 | 09:53 PM
nihad's Avatar
and my engine build... http://turbod16.com/viewtopic.php?f=27&t=42957&hilit=
I also have a ram horn manifold that i am thinking of using..and redoing the down pipe again... Ha.. I did some port work mostly on the exhaust i didnt want to mess with the intake port.. but did a little bit on the bowl's.. Check it out..
Old May 21, 2010 | 02:33 PM
welfarepc's Avatar
the intake ports are where most of the flow can be found. seats are also very important as well.
the exhaust can benefit from a raised roof but the exit should be left as close to stock as possible to help fight reversion.
the 59300 can easily make over 400whp. stick with what you got.
Old May 21, 2010 | 10:55 PM
nihad's Avatar
I all ready did the port work next time ill send it to RLZ out east..
Old Sep 20, 2010 | 08:53 AM
Terrible One's Avatar
if money wasn't an issue; the bisimoto 2.4 cam is the best imo. the zex 59300 is the better bang for your buck. do you have a dyno graph?
Old Sep 22, 2010 | 10:35 AM
welfarepc's Avatar
wow a lot has happened since this post...
i now firmly believe Coltcams.com is the best in the business. check out the dyno plot for my D16Z6 on 20psi/chevron pump gas.
i think it would be hard to beat this.
Old Sep 23, 2010 | 08:34 AM
Sales@Bisimoto.com's Avatar
If you want to go with one of our Bisimoto turbo cams let me know I will do what I can to assist you and potentially work out some sort of deal for you!
Randy@Bisimoto.com
Old Sep 29, 2010 | 06:34 AM
pinki07's Avatar
bisi cam are the best but a little pricy depending on ur price range may go with zex 59300
z6rodriguez
Dec 6, 2007 10:11 PM
whiteknightef
Jul 22, 2004 11:49 PM
JDMvtecDRAGSTA
Feb 13, 2002 02:28 PM
