ls-vtec build
Old May 17, 2010 | 10:09 AM
trever0x17's Avatar
Default ls-vtec build
ok so i am new at building motors, but my friend recently gave me a b18a1 block. So i figured the y7 is getting old, and i want to build an all motor build.
Im gonna start with building the block first, then get a b16 head.
so far the list of things i want to get is:
.golden eagle ls vtec conversion kit, 81mm gasket.
.b16b pistons
.golden eagle rods with arp rod bolts
.b16 head
.skunk 2 intake
some suggestion on other things would be nice.
Old May 17, 2010 | 09:47 PM
$hawNPeeZyy's Avatar
Default Re: ls-vtec build
A decent set of camshafts perhaps?
Old May 17, 2010 | 09:55 PM
trever0x17's Avatar
yah i was thinking about some blox stage 2 camshafts.
my main focus right now though is to rebuild the block i just had it cleaned today. Im thinking if i should buy a new crankshaft or not, because when the motor ran it spun a rod bearing i believe, and im not sure if that would of hurt it or not, cause from what i heard ls camshafts are pretty decent crankshafts, and it might be nice if its salvageable.
Old May 17, 2010 | 10:53 PM
honda_luvr_2000's Avatar
If you're not planning on boring the block 1mm oversize then I strongly recommend not getting an 82mm head gasket, but one that matches the bore.
Old May 17, 2010 | 11:12 PM
trever0x17's Avatar
prob good idea thanks
Old May 18, 2010 | 04:10 AM
kyden's Avatar
i would not use the pct pistons.
Old May 18, 2010 | 08:34 AM
trever0x17's Avatar
why is that?
i was reading they are .25mm oversized, would that mean i have to bore out my block?
Old May 19, 2010 | 10:52 AM
Malgerus's Avatar
I wouldn't recommend the PCT pistons either, they'll knock your compression up quite a bit, and you might have piston to valve clearance issues.
Get a set of PR3 or P30 pistons.
PR3's with a 3 layer headgasket and a B16 head = 11.3:1ish compression
P30's with a 3 layer headgasket and a B16 head = 11.5:1ish compression
I am using PR3's myself and I run 94 octane gas to avoid detonation.
riceball777
Mar 14, 2010 02:13 PM
b20_driven
Jan 31, 2009 11:18 AM
hatch b16a guy
Feb 3, 2006 04:26 PM
