jdm b18c new piston which are the best!!!!
Old May 16, 2010 | 07:57 AM
donvito#1's Avatar
Default jdm b18c new piston which are the best!!!!
so im putting new pistons in my jdm b18c swap the only internal upgrade i have is skunk2 stage one cams and gears but anyway i was thinking of getting some itr piston's but my buddy told me b16 pistons would work the best i guess they have a higher dome can anyone share some light on the best OEM piston i can use,, and i only want oem piston's
Old May 16, 2010 | 08:02 AM
d1ck's Avatar
Default Re: jdm b18c new piston which are the best!!!!
I believe the b16 "p30" pistons will give you the highest compression.
Old May 16, 2010 | 08:15 AM
donvito#1's Avatar
and putting some b16 piston is pretty stright foward like no problem valve hitting piston???
im looking to bump the compresson a smidge and have the motor last 100k+++
Old May 16, 2010 | 10:31 AM
AcuraLsSE's Avatar
it looks like no matter what OEM pistons you go with you won't really have to worry about the valves hitting the pistons. Unless you mill the had and deck the block. What pistons you choose is really up to what compression you want to run. Also the type r pistons come with a coating on the pistons which creates less friction.
Old May 16, 2010 | 01:15 PM
racebum's Avatar
why exactly are you changing the pistons? you also realize if you use new rings you have to re hone the liners right?
as others have stated it's all about the compression you want.
Old May 16, 2010 | 03:37 PM
Alan Senhoreti's Avatar
oem ctr pistons will give you the highest compression, valves and camshafts might need replacement.
Old May 16, 2010 | 03:38 PM
very true, so does the ctr's
Old May 16, 2010 | 06:25 PM
donvito#1's Avatar
i have low compression in cylinder one did a leak down test and it the block motor still ran decent just a slight miss no knocking or ticking more then likely it the rings because of what happen but i just want to replace the piston for a little bit mor power i think im gonna go with the b16 piston's
Old May 16, 2010 | 08:30 PM
racebum's Avatar
what cylinder head? with a pr3 head the p30 pistons are great, getting kind of high for a gsr head without pulling timing in the map or finding at least 95 octane. anything over 11:5-1 starts getting really finicky in 100 degree weather unless you pull timing when you have the tune done. also, if you're going to buy new pistons and rings, you might as well spend the extra 100 bucks to have it bored to 81.50mm and get the oversize pistsons. it will make sure the cylinders are true and give 1-2hp from the displacement increase.
Old May 16, 2010 | 10:42 PM
AcuraLsSE's Avatar
Take a look at these if you're looking to up the displacement a little while staying with an oem type cast piston. These are also coated in the same material as the type r pistons.
http://www.inlinefour.com/il4peprpi.html
Old May 17, 2010 | 04:54 PM
the b16b ctr pistons will give you the most power
Old May 17, 2010 | 05:23 PM
racebum's Avatar
Originally Posted by Alan Senhoreti
the b16b ctr pistons will give you the most power if you drive around on 100 octane race gas
fixed
Old May 17, 2010 | 10:48 PM
jdm_bones's Avatar
I like the JDM ITR piston, it has the same compression as the P30, but also the coat on the piston, then use a 2 layer head gasket if you wish to bump the compression even more, how ever, you might need higher octane when running high compression engine...California sells 91 OCT which sucks on high compression engines...just my .02
Old May 17, 2010 | 11:19 PM
AcuraLsSE's Avatar
I'm running the JDM ITR pistons on pump gas just fine. But I haven't driven around on a really hot day yet either.
Ryan#1
Oct 2, 2008 06:27 PM
hovic
Feb 25, 2007 06:47 AM
Mugen112
Oct 3, 2006 03:15 PM
b18sihatch
Jul 10, 2006 08:35 AM
SPOOLINmatt
Jan 13, 2006 06:13 AM
