b18b1 revs slowly
Old May 15, 2010 | 07:52 PM
eghatchfla's Avatar
Default b18b1 revs slowly
yepp i can be in neutral and hold it to the floor and it will rev reallllly slow, when it used to jump up to redline real quick. while in gear it doesnt have near the ***** it used to.
this just started happening and ive been trying to figure out what it is for the past 3 days..
just put new plugs and wires in and made sure ignition timing was right.
i need help!
please someone! any ideas????
Old May 15, 2010 | 07:55 PM
300whpej's Avatar
Default Re: b18b1 revs slowly
you seem to be getting used to the motor...also its a pretty slouchy motor. the only thing i can think of would be a lightweight flywheel if you arent throwing any cel's.
Old May 15, 2010 | 08:02 PM
eghatchfla's Avatar
nahh cant be geting used to it..
it used to spin once i hit 2nd and would chirp 3rd, but now it will arely chirp 2nd.
i can fel a huuge power difference, this was a very strong motor before..
Old May 15, 2010 | 08:21 PM
mortificationrock's Avatar
The VTEC is gone thats why.
Old May 15, 2010 | 08:26 PM
b20hatchek's Avatar
i think it could be a fuel problem, wiring issue with the fuel to air mixture, i bet theirs could be a sensor slowly going out, id tried reseting the ecu
Old May 15, 2010 | 08:29 PM
b20hatchek's Avatar
btw no gsr could get away from my ls in my del sol and it wasn't even running right so their no slouch, you dont really need vtec unless you want power at the top end
Old May 15, 2010 | 08:38 PM
eghatchfla's Avatar
ive reset the ecu plenty of times, but ill make sure to check some wiring tomorrow in the daylight.
but yeah the ls is in my gutted eg hatch and ive took down quite a few cars.. quick for what it is
Old May 15, 2010 | 08:57 PM
b20hatchek's Avatar
yeah their not awesome fast but quick for what it is, im fixn to drop 1 in my ek ill prolly just do some bolt on's i dont really care to do a ls/v
Old May 16, 2010 | 09:02 AM
eghatchfla's Avatar
any other ideas people.. i need this thing running right
Old May 16, 2010 | 09:40 AM
SchuittD16's Avatar
Disconnect your positive battery cable, and step on your brakes for 20 seconds. *this will drain your ECU of residual power* Reset your ecu, Take off your Fuel Filter, and blow through the top hole, if there is any resistance, replace it. Make sure your timing is right.
I know you said you reset your ECU but if its not drained, it will save the old information..another way is to remove the fuse under the hood, it will reset your clock and stereo though.
Old May 16, 2010 | 06:51 PM
eghatchfla's Avatar
ok i bought a new fuel filter and put it on, and reset the ecu like you told me too. its running a lil better but is still bogging 1k-3k
any thing else i should try??
Old May 16, 2010 | 07:29 PM
SchuittD16's Avatar
Check the resistance on your throttle body and the cable....could be too loose, or too tight. and check the intake manifold as well, just make sure its opening right, take off the intake and rev car from under hood and look in...
Does it run different cold? like start it up and drive, i swear mine does the same thing but runs soooo different when its started and driven as opposed to when its warm.
Old May 17, 2010 | 06:31 PM
eghatchfla's Avatar
ok i checked all that and its good, its running better now.. thanks alot man
Old May 17, 2010 | 06:41 PM
TylerB's Avatar
For future reference, bad timing will do this too.
Old May 17, 2010 | 09:11 PM
SchuittD16's Avatar
how was the play on your throttle body? cable ect? just interested
Tyler he mentioned he did check timing after he did the plugs / wires
Old May 18, 2010 | 05:20 PM
eghatchfla's Avatar
theres not too much play on the cable, feels normal to me..
but i got it running alot better now.
only thing is that it wil only run smooth and pulll hard if the timing is all the way advanced.. does this mean im off a tooth or two on the cam timing??
Old May 18, 2010 | 05:48 PM
b20hatchek's Avatar
yeah i think so^^^^ and your supossed to have a small amunt of play in the throutle cable
Old May 18, 2010 | 05:56 PM
eghatchfla's Avatar
alright i will try to line it up tomorrow, and ill reply and let you know
souchiem
10
Jun 18, 2013 06:13 AM
SOL-Hatchback
May 21, 2007 06:48 AM
G2Crash
Jul 9, 2004 02:12 AM
shermanyang
Jun 15, 2003 10:20 AM
