Another 5 lug conversion question?
Old Sep 12, 2002 | 04:35 AM
blacksoul's Avatar
Default Another 5 lug conversion question?
I did a search and found it very helpful even with pics. But a question i didnt see answered (and it may not matter?) is: Would i have to do more work than a 90-91 crx si because i have drums in the back? (brake booster, proportion valve, lines, etc.)
Anyways, this is what i need basically: "The only thing you need other than what is on the CRX is 94+ integra outer tie rod ends.
The rear trailing arms are the same. Just change the whole trailing arm, it bolts up to all the crx control arms.
For the front just put on the Type R spindles and the 94+ integra outer tie rods. Then just do up the bolts and bleed the brakes.
I used the original crx axles and the spindles were the Type R spindles."
Old Sep 12, 2002 | 07:02 PM
blacksoul's Avatar
Default Re: Another 5 lug conversion question? (blacksoul)
Old Sep 13, 2002 | 01:59 PM
blacksoul's Avatar
Anybody?
Old Sep 13, 2002 | 04:55 PM
d357r0y's Avatar
ya know.. i was thinking the other day.. couldnt you just get the rear 5lug hub and put it on your 4lug rear trailing arm? the cost seems like it might be a hell of a lot lower and its super cheap to take your discs to have them drilled for 5 lug..
havent decided about the fronts yet. but doesnt that seem it would work on the back?
sorry, thats kinda off topic
Old Sep 15, 2002 | 06:13 PM
blacksoul's Avatar
Once again.
akandok
Mar 31, 2012 07:24 PM
mitsubishiv5
Suspension & Brakes
Jan 18, 2009 07:50 PM
k20z
Feb 23, 2005 11:19 PM
Black R
22
Mar 22, 2003 08:47 PM
Turbo Lude SH
Aug 11, 2002 06:55 PM
