I just need a 5 lug CRX... how?
Okay. I need to convert my CRX to 5 lug. I dont care about brakes or anything. I just need it to be 5 lug. Type R conversion is my best bet?
I've searched and havent found any help. What parts should I look for and what exactly do I need?
Thanks in advance.
Thanks in advance.
Re: I just need a 5 lug CRX... how? (Turbo Lude SH)
what is so special about 5 lug that you have to have it? I think brakes are much more important. unless that is you have s2000 wheels, i would convert for those.
Andy
Andy
Re: I just need a 5 lug CRX... how? (87posCRX)
Well in the search you should have found lots of stuff, because I and some others have posted it before. But since im the nice guy I am, , here you go:
Type R 5-lug:
info: Its really simple. The only thing you need other than what is on the CRX is 94+ integra outer tie rod ends.
The rear trailing arms are the same. Just change the whole trailing arm, it bolts up to all the crx control arms.
For the front just put on the Type R spindles and the 94+ integra outer tie rods. Then just do up the bolts and bleed the brakes.
I used the original crx axles and the spindles were the Type R spindles.
more info: http://universe.svwh.net/car_stuff/da_5lug/
Type R 5-lug:
blacksoul
09-15-2002 06:13 PM
