play in shifter
So i been getting alot of play in my shifter and thought it was the bushings. Jacked it up and looks like theres play on the whole assembly i can move it back and forth from the bottom. Also that rubber ring or boot, not the bushing, is all ripped up. I have no idea whats this part called. Its the rubber boot that slides onto the shaft. Do they make stronger after market ones? cant find them anywhere. You guys think this calls for whole new junk yard assembly?
if you fix the bushings in the linkage it should fix it same problem with me friends crx you can buy a cheap set of hard rubber bushings from advanced just to see if it fixes the problem then you can buy i good bushing for it.
david420
45
Apr 3, 2012 07:43 AM
mrbuddha
Jan 28, 2011 12:30 AM
vestalfootball72
Jan 28, 2008 11:18 AM
