H22a Turbo set up
Old May 15, 2010 | 01:34 AM
flprelude22's Avatar
Default H22a Turbo set up
Im going to be starting my build and im kinda new to honda 4 cylinders. I currently have a 92 prelude with a 96 h22a W/ the LSD trans. ive put on the basic modes, exhaust, intake manifold, cold air intake, MSD ignition to keep it clean. Buddy took me in his trubo integra and now i want that. Im gonna have the block sleeved and a 88mm bore, which is a good tubro. i have the chance to buy a T70 with a 69 A/R. should i get this or is it to big?
Old May 15, 2010 | 02:22 AM
dagle's Avatar
Default Re: H22a Turbo set up
whats your goals? and how much are you looking to spend?
you'll wanna decide those two things first before you take the next step.
Old May 15, 2010 | 05:14 AM
Im planning on putting atleast 10 thousand into my project. Im gonna try to reach 600-700 hp. My plan is a 88mm golden eagle sleeved, mahle rods, and CP 9 to 1 pistons for the bottom end. have decided which head set up. but probably gonna go with DH racing, and BC cam, spring, valves. Im currently tryin to find a good topmount to. but the turbo is like 650 bucks for a t70. just wonderin if i should go ahead and get it. i dont know it thats gonna be t big or not
Old May 16, 2010 | 10:15 AM
j_wynn08's Avatar
build it up first before buying the turbo itself. With concern to the mahle rods, are you going to be increasing stroke? or keep it std stroke?
Old May 16, 2010 | 12:46 PM
yeah im just tryin to get some ideas on the turbo. im keeps std stroke. just going with a bigger bore.
Old May 16, 2010 | 02:25 PM
j_wynn08's Avatar
the best idea would be to do the motor dyno it and then see how much more you need to go with the turbo. you dont want to buy the turbo and then it not be enough and have to get another one
Old May 16, 2010 | 02:57 PM
Furious 2.3's Avatar
good luck with this build. cant wait to see it done.
Old May 16, 2010 | 04:26 PM
fastbb2's Avatar
gt4088r with a .83 a/r, good for 700+ hp... should spool nicely on a fully built h22 with a very good tuner
Old May 16, 2010 | 04:56 PM
g-gameslude18's Avatar
Keep the stock 87mm bore. By going with 88mm right off the bat, you are cheating yourself out of future rebuilds down the road.
Jimmydean771
Mar 24, 2014 05:01 PM
Drifter6508
Sep 27, 2010 09:44 PM
230 cougar
Aug 3, 2009 05:27 AM
94CDMeg
Sep 25, 2008 07:47 PM
Hondaen
Feb 12, 2006 05:08 PM
