2.38" vs 2.5" exhaust for turbo setup
Old May 14, 2010 | 11:25 PM
boxeocampeon's Avatar
Default 2.38" vs 2.5" exhaust for turbo setup
close
Old May 15, 2010 | 04:36 AM
Alfa Turbo's Avatar
Default Re: 2.38" vs 2.5" exhaust for turbo setup
Bigger (exhaust) is always better. Will the smaller size work, yes. As well, no.
Old May 15, 2010 | 07:56 AM
90blackcrx's Avatar
At the very least go with a 2.5
Old May 15, 2010 | 08:48 AM
Alfa Turbo's Avatar
Originally Posted by boxeocampeon
do you guys know any other company that makes a 2.5" exhaust piping besides kteller? and any other companys that make a muffler with a 2.5" inlet?
If I asked you were the sun was would you look at me a little funny? Cuz' that's how I am kinda' lookin' at you.
Old May 15, 2010 | 11:44 AM
alpha's Avatar
2.5" minimum. Just to give you an idea. A customer of mine went from a 2.5" exhaust to a 3.0" exhaust. Below are the results. He's not going to have me retune it until he does the 3.0" downpipe, ramhorn exhaust manifold (currently has a log manifold) and ITR cams (currently has GSR cams)
Went from ...
To ...
Old May 15, 2010 | 11:53 AM
nokturnal_munkeeboy's Avatar
right now i have kamikaze headers to be installed with a 2.5" collector.
im debating whether to put a kteller 2.5" exhaust piping with a DC sports 2.5" muffler or putting the full buddy club pro spec exhaust which is 2.38"
my future plans are turboing my d16 with a gt28r turbo. my goals are 300+hp
do you guys think it will be better to go with the 2.5" exhaust or 2.38"?? i also plan on using a test pipe and i dont believe they come in 60mm.
thanks guys
put it like this go buy muffler you like and go to a exhaust shop to get custom pipping done
Old May 15, 2010 | 11:58 AM
AlexDphoto's Avatar
Go kteller piping you wont be disappointed. and 3 inch.
Old May 15, 2010 | 10:25 PM
KTeller8's Avatar
basically it boils down to a few things. the size isn't much in difference as someone mentioned, but these are measured in OD (outside diameter). So even the buddy club at 2.36 is OD, so your looking at closer to 2.25" ID. KTeller can offer a 2.5" OD to give you a slight edge and benefit and I would look at the bolt up kit, where its easier to install and just pop on and go.. email me and i can save you a good bit off our list price if your able to purchase mild steel. stainless wouldn't qualify for the discount.
Old May 16, 2010 | 05:23 AM
azandford's Avatar
mandrel solutions sells a 3 inch piping kit that just needs to be welded for 175
Old May 16, 2010 | 07:19 AM
jerm__'s Avatar
go with the 2.5 inch. Maybe even 3.
Old May 16, 2010 | 08:20 AM
90blackcrx's Avatar
http://www.rcautoworks.com/catalog/i...9f6b1ab772f44d
Old May 16, 2010 | 09:29 AM
Rdriver's Avatar
I highly doubt you would see a difference on the dyno between 2.38" and 2.5". Not a lot of difference there. If your current setup is quite and you like it, I would keep it. You can always run a cutout for big power.
Old May 16, 2010 | 04:28 PM
AlexDphoto's Avatar
thanks guys for all the info. Say i decide to go to a custom shop to get the piping done it doesnt really matter as long as they use good piping right? and will 3" be okay before i boost?
why cant you just use a stock exhaust until youre boosted?
400whp
Apr 13, 2014 09:48 AM
kou-integra98
Oct 11, 2013 07:20 AM
Derek14
Mar 23, 2004 09:10 AM
D-SPEED
Sep 23, 2001 10:25 PM
