Oil pan gasket?
Old May 13, 2010 | 08:47 AM
ntcivic's Avatar
Icon2 Oil pan gasket?
I'm going to replace the engine oil pan gasket on my wifes car this weekend, she has a 96 honda civic. I didn't want to pay someone a few hundred bucks to do it
All I need is the gasket, do I need some type of sealant that goes on the gasket or the pan?
Old May 13, 2010 | 09:13 AM
Former User's Avatar
Default Re: Oil pan gasket?
I use this
over the entire length of the gasket, not just specific areas. Torquing the nuts and bolts to spec in the proper sequence is also important.
Old May 14, 2010 | 06:08 AM
ntcivic's Avatar
Thanks just bought that last night and I'm going to do it this weekend.
Old May 16, 2010 | 08:02 PM
ntcivic's Avatar
man this weekend I realized that this job actually takes a lot of time. You have to really get in there to remove the oil pan screws, and there is little space between one of the screws and the tranny.
Plus you have to also remove the pipe that runs just under the oil pan.... guess I'm going to see this through some other weekend, more work than I had first anticipated.
Old May 16, 2010 | 08:27 PM
RICKSAUTOMOTIVE's Avatar
use a 1/4 inch air ratchet with a 10 inch extension. after you get that exhaust pipe off and the cover plate on the lower part of the trans that covers the fly wheel or flex plate you should have the pan off in no time. it shouldnt take you more than an hour if you also clean the pan up real good.
Old May 16, 2010 | 08:28 PM
i think your car also has a cross meber running under the oil pan as well but its easy to remove as well.
Old May 16, 2010 | 08:31 PM
ntcivic's Avatar
I have to buy some towels to make sure I can clean it up.
Well see what happens next weekend. I will post some pics of what I'm working with, thanks for the tips on the tools.
Old May 28, 2010 | 07:51 AM
ntcivic's Avatar
So I changed the gasket, what a pain.
Two things, it seems to still be leaking though not as bad as it first was. I think the pan itself might be bad. looks like it got banged up once.
two, the only thing I noticed on my car is during warning it up now, it tends to rev up a few times.
Old May 28, 2010 | 01:50 PM
batey804's Avatar
u messed it up bro
batey804's Avatar
gotta get a new car now
Old May 28, 2010 | 01:51 PM
ntcivic's Avatar
Originally Posted by batey804
u messed it up bro
lol. thanks for the encouragement, na the pan was already messed up prior to me removing it, since the car was lowered before I think that caused the damage. I could tell with the dent it already had.
Old May 28, 2010 | 01:54 PM
D16SiHatch's Avatar
i could understand the bottom of the pan being dinged, but it seems unlikely the pan to block mating surface would have become tweaked somehow. is it possible the leak is coming from higher up? valve cover gasket, cam seal, crank seal, or rear main possibly?
Old May 28, 2010 | 01:58 PM
ntcivic's Avatar
I came to that conclusion, it might be another seal, though not the valve cover gasket since that was replaced and sealed and is no longer leaking.
I'm going to take a look at the cam seal, crank seal, but I think it might be the pan itself.
Old May 28, 2010 | 02:07 PM
ntcivic's Avatar
Here are some pictures I took
Old May 28, 2010 | 02:40 PM
madracer's Avatar
when changing the oil pan gasket you need to use Honda Bond, its the best thing to use and you will be happy after, the rtv is ok but the Hond Bond is much better. Only put the honda bond around the bolt holes on both sides of the gasket. Note: Do not paste the honda bond on the entire gasket.
Old May 28, 2010 | 02:41 PM
blueblur1984's Avatar
From: Marin county (aka death's waiting room), SF bay area
Before you open up the gasket I've hear of quite a few people changing out their own and STILL having the leak. I opted to have my mechanic do it and he actually advised against it. He told me to start using 10-30 oil as opposed to the 5-30 the manual said and it didn't leak again after that. I'd say try moving to a more viscous oil before pulling apart the car.
Old May 28, 2010 | 09:17 PM
OCFIT85's Avatar
you sould never put silicone on the whole gasket. it defeats the point of even buying a rubber gasket it the first place. It is common on these gaskets when you are replacing them that that you could have left a little metal ring around one of the studs that sicks out of the block causing a "double gasket" effect witch leads to huge leaks. The honda bond should only go in the corners of the rounded out part for the crank to seal imperfections in the corners. older cars are also known to start having rear main seal leaks. clean your IAC for the idle problem.
Old May 28, 2010 | 09:19 PM
OCFIT85's Avatar
oh also oil pan bolts need to be torqued to eight foot pounds
Old May 31, 2010 | 03:00 PM
ntcivic's Avatar
Thanks guys,
seems everyone has their own technique, I have the haynes manual coming so i'm going to wait until then.
Old May 31, 2010 | 04:09 PM
D16SiHatch's Avatar
i use ALLDATA whenever possible. use this if you wish :p
Old Jun 1, 2010 | 10:43 AM
boxeocampeon's Avatar
bouta change out my oil pan gasket this weekend. do i have to use a torq wrench?
Old Jun 1, 2010 | 12:58 PM
siblues's Avatar
Yes and the torque specs are further up on this page.
Old Jun 1, 2010 | 03:06 PM
ntcivic's Avatar
thanks for that, but my engine is a B15
hey is ALLDATA free?
Old Jun 1, 2010 | 05:32 PM
D16SiHatch's Avatar
no such thing as a b15. i assume you mean d15? i would imagine your wifes car has the stock engine in it though right?, in which case it would not be a d15, it'd be a d16y something. if you're not sure, the engine code is stamped to the left of the exhaust header. it will look like this
http://i85.photobucket.com/albums/k6...tyle/D16y8.jpg
and to your other question; unfortunately no, ALLDATA isn't free.
Old Jun 1, 2010 | 09:10 PM
ntcivic's Avatar
Yes I meant to say D15 B7 on my 95 civic dx is my engine, my wifes is a 96.
pinoyboy204
29
Apr 28, 2017 07:14 PM
StreetRacinThug
Dec 21, 2006 08:44 AM
mstewar
Aug 1, 2005 10:50 PM
ringgold
18
Sep 20, 2004 04:28 AM
yellowbulbs
Jul 17, 2001 01:12 PM
