Side-marker question?? "Bulb size"
I did some research and was wondering the size of the side marker bulb for my civic sidemarkers..I believe its a T10 wedge but not to sure of that..Can anyone confirm that, im trying to find a double filiment buld so it will blink..
Thanks, NICK
Thanks, NICK
Re: Side-marker question?? "Bulb size"
So correct me if I'm wrong, but the side markers you're talking about are not USDM factory. Also they are currently a 2 wire bulb socket with a single filament bulb in them, right? Well if that's the case on the current bulb, then you're going to have to make some modifications to the side marker assemblies to put in a dual filament bulb & socket. Just wire them to your turn signal circuits since you want them to flash.
I'm assuming though, that you want them on with the marker/parking lights and flash also with the turn signals... Yeah that's a tricky feat to tackle. It either requires relays (that tend to fail due to that type of use) or some fancy rewiring of the lighting circuits.
There may be another side marker lights setup out there, but I couldn't tell you what it is or where to find it.
teggyluva90
08-27-2013 04:45 PM
EvDog03
Honda Civic (2001 - 2005)
11-30-2008 10:56 AM
