CEL problem on 90 DA
Old May 12, 2010 | 09:15 PM
00323's Avatar
Default CEL problem on 90 DA
so i had code 6 on from a bad Distributor and replaced it with a NEW one and still have CEL on...ive tried disconnecting the battery for a while...pulled the ECU fuse..pulled the hazard fuse and even tried disconnecting the ECU...nothing still have CEL...any help? maybe im doing something wrong.
Old May 12, 2010 | 10:56 PM
MD426's Avatar
Default Re: CEL problem on 90 DA
If you reset the ECU and the CEL immediately comes back on with the new distributor then it's probably a bad connection in the connector or wiring harness for the distributor.
Old May 12, 2010 | 11:28 PM
seanbev24's Avatar
This sounded strange to me so I googled obd0 codes and clicked on 5 links...
1 link (g2ic teg tips) said code 6 is crank sensor (dizzy)
The rest of them said code 6 is ECT (coolant temp)
Then I got off my lazy *** and grabbed a haynes manual from the garage. It also says ECT.
Old May 13, 2010 | 04:09 AM
MD426's Avatar
He's right, since yours is a '90 it's OBD0, I also saw ECT, Engine Coolant Temperature. I'm guessing that it comes on when you overheat. Can you verify that? Let the car idle for ~15 mins or take a drive, does the coolant temperature get passed the middle on the gauge?
Old May 13, 2010 | 08:16 AM
seanbev24's Avatar
To check the ECT:
-Get the engine to full operating temp (t-stat open, fan cycles on a couple times)
-Turn off car
-Unplug ECT
-Use an ohmmeter and measure the resistance between the 2 terminals on the sensor.
-If resistance isn't between 200-400 ohms, the sensor is bad.
To check the circuit wiring:
-With the sensor still unplugged, turn the key to ON but don't start the car.
-Measure the voltage between the terminals in the plug on the HARNESS side.
-There should be 5 volts.
-If not 5 volts, there's a problem in the circuit wiring or the PCM itself.
Old May 14, 2010 | 03:16 PM
00323's Avatar
thanks got a new sensor and CEL came off..new problem now...after driving 10-15 minuets CEL turns on... i pulled over to read the code but nothing...so drove off and 5 mins later came on...read it while the car was on and still code6..no CEL on startup or anyhthing..comes on after a while driving but then turns of when i turn off the car...any helP?
Old May 14, 2010 | 04:40 PM
MD426's Avatar
It will come on when there is a problem, it wont stay on. Your overheating for some reason. The ECU should store the last 3 codes before it's reset though. I would flush your cooling system, air bubbles in the coolant system can cause over heating too.
Old May 14, 2010 | 04:50 PM
00323's Avatar
the temp needle is always in the normal operating temperature..right in the middle...i just did a coolant flush a month ago..
Old May 14, 2010 | 04:53 PM
MD426's Avatar
There can still be air bubbles in the lines. I'm pretty sure the ECT sensor acts like the oil pressure sensor, it comes on when there is a problem then goes out when it's fine. The sensor is getting hot from somewhere or is shorting out.
Old May 14, 2010 | 04:59 PM
00323's Avatar
its a new sensor....how can i fix this? or how can i get the air bubbles out..but if it was overheating then why is the temp needle fine?
Old May 15, 2010 | 10:27 AM
00323's Avatar
bump
Old May 17, 2010 | 07:45 AM
00323's Avatar
ttt
Old May 27, 2010 | 05:34 PM
00323's Avatar
ok so i got my bros multimeter and got 5V out the harness plug...then measured the resistance on the sensor and got a little over 200....so reset the ECU twice still getting CEL while driving
Old May 27, 2010 | 06:00 PM
fcm's Avatar
fcm
Old Fart
Check your 02 sensor (s), a CEL coming on when driving is an indication that there is a problem with one of the engines emission control systems.94
Old May 27, 2010 | 08:26 PM
00323's Avatar
its showing up as code 6 when it comes on....after a couple mins of driving it comes on and ive pulled over while the car was still running and showed code 6 witch is ECT...its a new sensor ive check the voltage and the ohms and everything is fine
Old May 27, 2010 | 09:06 PM
seanbev24's Avatar
FCM- Would the ECT not be considered an emission control? I figure it is since the ecu needs to see the right temp to run closed loop?
It seems to me if 5 volts is getting to the sensor and the sensor is new, the only part of the circuit that could be bad is the ECU.
I know air bubbles can do strange things, but I would think if that were the issue, there'd be other problems with overheating, sending unit, heater temp, iacv, etc.
Old May 27, 2010 | 09:10 PM
00323's Avatar
no overheating temp stays at normal operating range...ill switch out the ECU and see how that goes
Old May 28, 2010 | 05:46 AM
fcm's Avatar
fcm
Old Fart
The ECT sensor is part of the emission control and I understand that he is still getting the code 6, but taking into account that the ECTS is new, voltage is good, impedance is within range, overheating is not an issue, I am assuming that the sensor is not the issue, nor is coolant, [low or bubbles in it] so it must be something else and a CEL when driving is most commonly caused by a problem with the 02 sensor.
I do agree that it can also be a problem with the ecu/ecm, mainly because of the code 6 still showing up, it does make sense, ECTS is good but still getting code.
I would ask, is the code being cleared properly? 94
Old May 28, 2010 | 07:25 AM
00323's Avatar
yes i properly reset the ECU a couple times already
Old Oct 7, 2010 | 08:51 AM
boondocksaint3c's Avatar
I have the exact same problem on the 91 i just bought... :/
Gonna replace the o2 n see what happens
SkIp_Civic_Ek6
Nov 27, 2019 10:08 AM
egvtec
Apr 17, 2010 04:58 PM
DMBHokie22
Jun 27, 2005 09:48 AM
EJ2-Fluffy
Jan 23, 2004 05:51 AM
sparkz
Jul 14, 2001 05:41 PM
