Shift linkage
Old May 12, 2010 | 06:14 PM
Matt_Jagg7's Avatar
Default Shift linkage
Pulling the engine/trans outta the 95 GSR, only thing holding on is the shift linkage. How do i disconnect the shift linkage from the trans? Any help will b great!!! Thanks!!!
Old May 12, 2010 | 06:16 PM
blackKready's Avatar
Default Re: Shift linkage
theres a boot where the linkage enters the tranny. pull it back , pull the flat C clip off the shaft. theres what we call the "bitch" pin under it , lol. try and guess why we call it the bitch pin? haha. get a punch that fits the outside edge of the pin , if it fits inside the pin it wont work. use a hammer and the punch and beat the pin out from bottom to top. the other linkage is a simple 12mm bolt.
Old May 12, 2010 | 11:50 PM
seanbev24's Avatar
X2 to that, except for the 20ish times I've done it, it's never been a bitch.
PB Blaster, use the right sized punch, hit it with a BFH. Maybe i've just been lucky?
Old May 13, 2010 | 12:29 AM
AcuraLsSE's Avatar
Same here... never had a problem getting it out. You just need enough room to get a good swing with the hammer.
Old May 13, 2010 | 01:18 AM
vtaker's Avatar
or if you can't get it, just disconnect it from the shifter side and then get the pin out when you have the trans out.
ALLMOTOR CRX
11
Mar 29, 2007 07:34 AM
honda4674
Jun 24, 2006 12:45 AM
sleeper_gsr
Sep 7, 2005 06:16 AM
MR. MIYAGI
Mar 12, 2004 12:34 PM
