Wiring Guru's! Fog light Help
Old May 12, 2010 | 02:00 PM
Ef8crxsi4u2nv's Avatar
Icon2 Wiring Guru's! Fog light Help
Okay Here's the deal, Awhile ago i bought 98' hatch with a 99'-00' front with the fogs already on. The guy i bought it from wired the fogs directly into the fuse box( The red wire coming from the bay harness) so my switch doesn't work. So i got a whole new set from Pwjdm. My question is, when i took the red wire out of the fuse box and connected it to the red wire from the switch, it melted the fuse in the engine bay fog harness by the relay. The brown 1 wire plug was connected to Acc #5 at the time. Whats going on?
Also i've searched and read through about 20 different threads and each one say's to plug the brown 1 wire plug in different spots. So which one is it?
Old May 12, 2010 | 03:37 PM
Default Re: Wiring Guru's! Fog light Help
Bump! C'mon guys help a brotha out
Old May 12, 2010 | 06:27 PM
I'm pretty much stumped on this fella's. Any kind of help at all or some insight on this would be much appreciated! Wiring's not my thing
Old May 12, 2010 | 06:32 PM
EJeff8's Avatar
Well, you plug it into a constant fuse of power fuse? Also, is it shoved under a fuse of is it plugged into one of the spots under them?
Old May 12, 2010 | 06:42 PM
^ I'm sorry but i couldn't understand what you just said :/ Right now my fuse box has a red wire shoved into a 7.5 fuse thats for my parking lights. It works but its hella ghetto when i have a switch that could be used. Just need to figure out how to make it work!
Old May 12, 2010 | 07:00 PM
EJeff8's Avatar
Eh, shoving wires under fuses isn't that ghetto. I, personally plan on working my fog lights into my parking light system instead of using the damn separate switch. Perfection be damned.
Old May 12, 2010 | 07:08 PM
Yea i guess i agree. It's not that ghetto but when you got (2) switches now and can't even use them, kinda makes me a little mad. How are your's wired up now? I mean i'm not a noob with wiring, i just don't like doing it nor do i like when it's not wired correctly. I wanna use my damn switch! Thanks though. Any more ideas?
Old May 12, 2010 | 07:11 PM
EJeff8's Avatar
I don't have them wire yet. But if you want it done right, I'm pretty sure there are ports under each fuse that you can plug a connector into. I think. You can also just run a wire directly to your positive terminal, if someone scrutinizes your engine it may not look the best, but it's one wire that runs to your terminal big whoop. Then just run your switch wiring and bam! You get your switch. But... they won't turn on automatically. You have to use the switch everytime, separate from your low beams and parking lights. That's cumbersome personally.
Old May 12, 2010 | 07:13 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Pull all the previous guy's isht out - the moment things start melting (ie., FIRE HAZARD) - then I need to know that it's done right. If it's electrical, then that's gonna basically mean start at square one.
Old May 12, 2010 | 07:17 PM
EJeff8's Avatar
^This dude is also right. When something starts to melt, there is no salvage. Only re - doing.
Old May 12, 2010 | 07:28 PM
Werd. Thanks for the input. It did melt the fuse holder in the engine bay when the brown plug was in Acc #5. So i moved it to 3 and it works but thats cause the previous owner ran a power from the battery and not the Right way from the switch. So any pics on how to go about the Right way of doing this? DeSchlong.... Chime in anytime
Old May 12, 2010 | 07:30 PM
EJeff8's Avatar
Ah, see the owner did what I said, but just obviously ****ed it up somewhere. I wouldn't have a melting issue
Old May 12, 2010 | 08:12 PM
deschlong's Avatar
Loved
Community Favorite
Buttering me up won't work
I will only suggest that you ditch the Password B.S. wiring and do it right -- wire it up like OEM. Attached is the wiring diagram for this. Read. Understand. Journey to a higher mental plane.
JPEG wiring diagrams (click for a larger image):
Old May 13, 2010 | 12:44 AM
Majyk's Avatar
This reminds me that I need to wire up my fogs. I am going to wire them to my park lights in my EJ1.
Old May 13, 2010 | 11:06 AM
Alrighty Mr. DeSchlong, i wasn't able to open the file you gave me It kinda worked but all that i could see was japanesse words. I'm not too good at reading it... lol
Old May 13, 2010 | 11:10 AM
deschlong's Avatar
Loved
Community Favorite
Hmm, yeah my instructions didn't include learning Japanese. Don't know what's wrong (do you need to upgrade your Acrobat reader?). Will repost as a JPG.
Old May 13, 2010 | 11:26 AM
98civdx's Avatar
Master Detailer
throw the pwjdm crap in the trash. My friend had this kit in his 96 with 99 front end and he had it in his car and it shorted and melted the wires.
Hes now useing wireing for a 96-98 civic. I belive the brown plug goes into #4 on the fuse box, they should turn on with parking lights unless you have the switch off.
Old May 13, 2010 | 01:34 PM
Quick little Update: I've been outside working on this crap and Wow. It was alot worse than i thought. I pulled the front bumber off to find that all the fog light clips have been cut off and connected with wire crimps! The ground wire has been cut and crimped, wire's Effin everywhere! I have come to the conclusion that if you can't do something Right, Don't do it! So now with both hands bleeding and the fog lights Working, (OEM working i might add) i'm happy now Did a mild wire tuck while i had everything apart also. So thanks to all who have helped out.
Old May 13, 2010 | 01:53 PM
deschlong's Avatar
Loved
Community Favorite
Sounds good. Diagrams updated above with JPEGs - might help someone out.
Old May 13, 2010 | 01:55 PM
Good looking out Mang!
TooManyHobbies
Sep 22, 2014 05:12 PM
crist488
Lighting
Jan 8, 2010 09:55 AM
efjones9
Audio / Security / Video
Jun 10, 2009 08:33 AM
kyorishin
10
Nov 13, 2006 08:14 PM
honda06si
Honda Civic (2006 - 2015)
Oct 9, 2006 12:48 PM
