1994 civic h/b ls swap axle problem
Old May 11, 2010 | 04:23 AM
hebrewhammer's Avatar
Default 1994 civic h/b ls swap axle problem
i have a eg with a ls swap i recently had the outer cv joint on the axle pull apart, i replaced the entire outer shaft only for the same thing to happen to the new one no more than a day later, the car still drives as it is not completely pulled apart but when i am on the gas above about 50mph the car vibrates, the last axle i had in lasted since the swap was put in almost 2 years ago, the motor mounts are good as are the ball joints im at a loss thanks for your help.
Old May 11, 2010 | 04:56 AM
JDM215's Avatar
Default Re: 1994 civic h/b ls swap axle problem
well first off what kind of axles are you using?
Old May 11, 2010 | 05:49 AM
Matt93eg's Avatar
Yes, this needs to be answered. OP, as he said, which axles are you running so we can determine if you are using the right ones or the wrong ones. Sounds like the ones you are using might be to short.
Old Sep 24, 2012 | 11:25 AM
sketchfast's Avatar
I'm trying to figure out what axles i'll need for my car. I have a 94 civic dx and i want to do a h22 type s swap. I'm trying to learn as much as i can and i'm usually asking my buddy tons of questions. I've looked online and have found so many different types that i have no idea.
thanks
widebodyeg
May 5, 2007 02:34 PM
EK18
Nov 8, 2006 11:44 AM
92civeg
Aug 24, 2004 07:09 PM
rice4life
Mar 5, 2004 06:13 AM
