help gsr wont start
Old May 10, 2010 | 06:18 PM
SOHConthis's Avatar
Default help gsr wont start
well the other day i got a gsr hatch but its been sittin for a good 8 months now today and yesterday iv been trying to start it . all i done to it was put new plugs and changed the oil and oil filter . iv tried everything i can like got 2 other dizzy'z but still no spark ,ckecked all the fuses and there good , i have used a good workin ecu , i even changed the engine harness and still no spark. anybody ever had a problem like this .car was also wrecked broke the tranny but nothin bad if that helps wit anything i doubt it tho.need to know somethin asap have to do a swap and sell the shell thanks ht.
problem solved did not have a main relay.
Old May 10, 2010 | 06:22 PM
shogee's Avatar
Default Re: help gsr wont start
checked the ground connections too?
Old May 10, 2010 | 06:25 PM
SOHConthis's Avatar
has plenty of ground . also it does get fuel
Old May 10, 2010 | 06:28 PM
shogee's Avatar
well seems like the igniter isnt getting power, got a wiring diagram?
Old May 10, 2010 | 06:51 PM
spoon_fed_civic's Avatar
heres what i would do
gas
firing order
main relay
tranny ground and the one on the thermostat
make sure the map sensor and tps arent reversed
thats just a couple easy ones to check out first
Old May 10, 2010 | 09:11 PM
SOHConthis's Avatar
anyone have other ideas
Old May 11, 2010 | 06:24 AM
SOHConthis's Avatar
bump.
Old May 11, 2010 | 06:51 AM
rnomad's Avatar
i had the same problem with my first swap the motor ran in the car we pulled it from and we dropped it in my eg it did nothing i even changed the wire harness and the ecu only to find out that i just needed to clean the grounds on the body and the motor and the bolts with a wire brush
Old May 11, 2010 | 12:13 PM
SOHConthis's Avatar
ill try that but dnt think that would get the dizzy to spark
Dlamazing
26
Aug 8, 2017 10:26 AM
jdm201010
Mar 18, 2014 11:51 AM
1baddturbosi
Jul 24, 2007 06:52 PM
lil'ek
Jan 9, 2006 08:38 AM
b18c195
Apr 21, 2003 06:40 PM
