99 civic auto to 5spd
Old May 9, 2010 | 06:23 PM
spoon_fed_civic's Avatar
Default 99 civic auto to 5spd
who ever said that you can just change the brake pedal out with a 5spd on is wrong.i just spend the last hour and half trying to do this cause i told it work on a thread i read on here.so now i have to tear apart everything to get the pedals in.just thought i let you guys know.
maybe i just got the wrong year pedal set up idk.i thought all 5 spd pedals are the same on 92-up civic so please correct me if im wrong thanks.
also do i need to swap to a manual brake booster or can i still use the auto booster just fine?
thanks for all the help just let me know thanks
Old May 9, 2010 | 06:29 PM
Linked's Avatar
Default Re: 99 civic auto to 5spd
it does work, on an EG civic, should be the same with the ek
the clutch pedal has its own independant harness
the brake and gas pedal are on the same harness directly above the steering column
the brake pedal is held in by a pin that secures it to the master cylinder that is locked with a cotter pin
the brake pedal is then held in by ONE bolt at the top of the harness that is used as a pivot point
remove those two and the brake pedal comes out with some wiggling
and the 5spd brake pedal is mounted EXACTLY the same
Old May 9, 2010 | 10:29 PM
Nope not on mine.
the auto brake switch is lower on the auto and i couldnt make just the 5spd brake pedal work at all.i could of but wouldnt of had brake lights.i just spend the last hour or so putting on the whole 5spd gas and brake pedal.an it was a pain in the ***.but at least its all dont right.i should take some pics so that u guys will see what im talking about exactly
jdm_ek_noob
Apr 3, 2015 08:40 PM
EG Civic Pat
Mar 20, 2014 10:26 AM
coletrain_eg
Jun 20, 2011 09:22 PM
grandtheftlunchbox
18
Sep 3, 2008 07:37 PM
SLO Sol
Nov 28, 2005 08:31 AM
