injectors??????
Old May 9, 2010 | 04:43 PM
JDM C.A.R's Avatar
Default injectors??????
does anyone know what are the colors of the injectors in order facing your car from the front and starting with your left hand as the first one for a d15b.
thanks
Old May 9, 2010 | 06:29 PM
JDM C.A.R's Avatar
Default Re: injectors??????
its an ej1 by the way.
Old May 9, 2010 | 06:36 PM
JDM C.A.R's Avatar
anyone?????
Old May 9, 2010 | 06:44 PM
300whpej's Avatar
injector colors? thats something new to me. i was always under the impression that injector firing order was irrelevant and were colorless
Old May 9, 2010 | 06:54 PM
D16SiHatch's Avatar
the injector firing order is definitely extremely important
op: i assume you want to know the wire colors.. i however don't know what they'd be. assuming your harness isn't in shreds it should be obvious which wires go with which injector though..
Old May 9, 2010 | 07:31 PM
300whpej's Avatar
honestly to me that makes no sense. maybe i know less than i think (very possible) but as long as the injectors are the same (240cc 310cc 550cc etc) the order they are placed on the fuel rail doesnt matter. the injector clips should only be able to reach one injector and can only fit into the intake manifold one way. maybe we have a mis communication issue here???
Old May 9, 2010 | 08:09 PM
JDM C.A.R's Avatar
thats what i should of asked first if the injection order matters. there clipped properly and everything i was just curious.
Old May 9, 2010 | 08:54 PM
D16SiHatch's Avatar
yea we sure do lol. when you say firing order that makes me think the order in which the injectors are firing.. not the order in which they are placed in the fuel rail. injector firing order is important, any given injectors placement on the rail is not.
Old May 9, 2010 | 09:20 PM
JDM C.A.R's Avatar
well theres to answers whom should i beleive.lol i dont know if its comment sence since the wireing on the 4 injectors are different colors its because they were ment to be in a properly order if not what was the whole point of them being different. would the car even start if the injectors are mist place since your saying injector firing is important.?
Old May 9, 2010 | 09:30 PM
D16SiHatch's Avatar
depending on how muffed up the wiring is the car might kind of run or it may not run at all. since you seem unsure of which wire goes to which injector position i would suggest that you use a multimeter and do a continuity test to figure out which wire is going to which injector position (a1,a2,a3,a5) at the ecu.
Old May 9, 2010 | 10:39 PM
JDM C.A.R's Avatar
ill try that out tomorrow since is my day off. will see what happens
Old May 10, 2010 | 07:19 AM
RICKSAUTOMOTIVE's Avatar
if you are saying that you have different color injectors, then its possible that they have been replaced one or two at a time. junk yard cars and new ones from autozne could all be different colors depending on the aftermarket manufacturers prefrence and cars they came off of. they should have all been replaced at the same time with new ones IMO. if you mean somehing different than individual injector colors then obviously i'm lost. i just woke up LOL still got my full cup of coffee
Old May 10, 2010 | 07:22 AM
JDM C.A.R's Avatar
wake up to ht.lol i ment the wiring of the injectors not the injector colors sorry about the confusion
Old May 10, 2010 | 07:30 AM
thats okay. i'm still wakin up LOL
Boostbuilds
May 16, 2013 06:23 PM
RICE POLICE SIP
Feb 13, 2010 10:01 AM
INTEGRA_boy
Dec 13, 2005 12:22 PM
98-0688
Aug 31, 2004 12:00 PM
B18C1_T
Aug 13, 2003 01:27 PM
