23'' slicks on a turbo car
Old May 9, 2010 | 05:24 AM
BLK2DOOR's Avatar
Default 23'' slicks on a turbo car
I have exospeed wheels and M&H slicks but there 23'' I want 24.5. should I exchange them or try the 23? It will be on a hatch that will be gutted with a 57 trim d16z6 with around 400+whp once tune hopefully. Stock geared tranny with a lsd. I wanna pull 1.6 to 1.5 short times and make it thru the traps without being on the rev limiter and have a good trap. Please chime in guys kinda **** that I had to wait on them to get the wrong ones.
Old May 9, 2010 | 06:16 AM
90dxhmt's Avatar
Default Re: 23'' slicks on a turbo car
That should be a perfect size for that tranny and hp level. Check here
http://www.fatboyraceworks.com/gears/
Old May 9, 2010 | 08:09 AM
Mr. Em1's Avatar
yeah you will be cutting it close, it depends on what you are going to be revving to.
Old May 9, 2010 | 08:21 AM
Honda Bull's Avatar
Depends what you rev to, what you trap, and what 60' times you are able to achieve.
Also, just because you say "stock geared tranny", we can't just assume it's the Z6 trans given that you can have any D-series trans on there. Is it for certain the Z6 trans?
Old May 9, 2010 | 03:10 PM
BLK2DOOR's Avatar
I hope its a z6 trans gotta check into that but i think it is and thanks
Old May 10, 2010 | 02:11 PM
nsxmatt's Avatar
Try the 23's and get the most out of them before going bigger. Too many people rush to bigger slicks and bigger drivetrain problems. If people can run 1000whp and run 8's with 24's I'm sure you'll be fine on 23's.
Old May 10, 2010 | 08:07 PM
theidealone's Avatar
Regardless, D series gearing sucks. 23s will be just fine.
Old May 11, 2010 | 02:32 PM
gizzmo222's Avatar
My buddy has about the same setup and pulls 1.6 60's and is just at his rev limiter so it's really up to you, he seem's pleased with his setup.
TurboGoKart
May 25, 2006 04:35 AM
fast2camciv
Apr 20, 2005 01:38 PM
BseriesHatch
Nov 10, 2003 09:44 AM
JG Luder
Jun 1, 2001 04:02 PM
