Wobbly shifter on my 98 EK Hatch
Old May 6, 2010 | 07:03 PM
ChangT's Avatar
Default Wobbly shifter on my 98 EK Hatch
I have a REALLY really really Wobbly shifter, bud says might be bushings and so we looked at it..and it was really rusty down there. Should we try and tighten it to fix it? or can i buy like new parts for it? any ideas?
Old May 6, 2010 | 07:08 PM
raidacaipo's Avatar
Default Re: Wobbly shifter on my 98 EK Hatch
new bushings.. you can go aftermarket if you want like energy suspension bushings.. But yeah you can see if its loose down there first.. also check the boot to see if its ripped or not
Old May 6, 2010 | 07:15 PM
b20hatchek's Avatar
that'll help but what will really help is a new spring pin for the linkage 2 bux at honda
Old May 6, 2010 | 09:43 PM
googootim's Avatar
x2
Old May 7, 2010 | 10:39 AM
gsrcoupee's Avatar
naaa all you need is any cheap poly bushing and throw it in.. itd be tight no questions.
Old May 7, 2010 | 01:53 PM
ChangT's Avatar
So just find buy new bushings? or atleast find some on CL?
Old May 7, 2010 | 02:06 PM
Deetz's Avatar
Crazy Honda Guy
Old May 7, 2010 | 02:16 PM
ChangT's Avatar
Where can i get that at? You think imma have to order online? can i run to like Autozone or something
Old May 8, 2010 | 10:04 PM
ChangT's Avatar
Bump!
Old May 9, 2010 | 12:03 AM
EFstyle's Avatar
the bottom of the shifter where the linkage connects is probably more the cause then the bushings them selves. do the bushings when u do a shifter.
Old May 9, 2010 | 12:15 AM
Deetz's Avatar
Crazy Honda Guy
The bushings are cheap and easy to get at any performance car place, like $12-14
I bought a pair for my type r linkage last month. It's a 15 mins install
Old May 9, 2010 | 07:12 AM
ChangT's Avatar
Hmmm so you guys think i should get a new Linkage and some new bushings? sounds like thats what its coming to 8)
Old May 9, 2010 | 07:30 AM
mctonyb's Avatar
I just fixed the same problem on my 97 hatch. I changed all the bushings (2 and the engine, and the one behind the shifter under the car) and problem solved. Got all the parts from Honda for a total of $35~ CDN.
Old May 9, 2010 | 07:34 AM
h2def's Avatar
u dont need to change the linkage.just do the bushings,but check the bolt at the bottom of the shifter first.but dont tighten it to much cause it will make it to tight and hard to move the shifter
hillbillycivic
Mar 13, 2013 08:14 PM
youngturbo
Honda Civic (2001 - 2005)
Nov 7, 2009 09:37 PM
totsie7944
Mar 19, 2009 01:09 PM
SleepyTow
Jul 16, 2008 06:41 PM
glock
May 10, 2002 04:29 PM
