revhard cast manifold & garrett turbo
Old May 4, 2010 | 06:00 AM
LSej1's Avatar
Default revhard cast manifold & garrett turbo
Anyone running a revhard cast manifold with a t3/t4e garrett 4 bolt turbo? I am having problems with the fit bc its hitting the block...from what i can see its hitting the ID plate of the block...heres the block and how much was cut out thus far...still wont fit.
Old May 4, 2010 | 07:39 AM
dpetro1's Avatar
Default Re: revhard cast manifold & garrett turbo
you will have major block clearance issues with a 4-bolt turbo, probably wont work at all. you will need to shave the block ALOT. you should switch to a 5-bolt turbo and even then it may require some trimming.
Old May 4, 2010 | 07:48 AM
th3pwn3r's Avatar
I guess there's only one thing you can do right?
Old May 4, 2010 | 04:42 PM
LastGenEK's Avatar
gotta flip the turbo and get new down pipe and remove AC componets
Pressure wash that engine bay too haha
Old May 4, 2010 | 06:22 PM
LSej1's Avatar
would flipping the turbo work? and just buy a 4 bolt non-ac downpipe?
heres another problem
Old May 4, 2010 | 06:33 PM
Fabworx's Avatar
What you could do right is buy a manifold that is built right. your so-pose to build your manifold to work with your motor, not make your motor work with your manifold.
Old May 4, 2010 | 06:36 PM
LSej1's Avatar
I didnt make MY manifold....revhard did....talk to them about their fabrication
Old May 4, 2010 | 07:09 PM
keving85's Avatar
i notched my block to fit my 60 trim turbo...been like that for a year
running the rev hard manifold and percision turbo
Old May 4, 2010 | 07:30 PM
Mr.Spec's Avatar
itll work with the RH. just a TON of block grinding. St00pid used to do it back in the day with cheesefrogs setup
Old May 5, 2010 | 03:17 AM
crxboy111's Avatar
flip the turbo and but a 5 bolt dp and call it a day.
Old May 5, 2010 | 04:58 AM
dpetro1's Avatar
precisions are 5-bolt, which fit much differently. the OP has a 4-bolt causing his problems
you have a few options
1. flip the turbo and get a new downpipe
2. get a 5-bolt turbo
3. try to track down an old inlinepro 4-bolt mani (they space the turbo out further and your current dp might still work with it)
either way it looks like you will need to modify the IC piping.
Old May 5, 2010 | 07:16 AM
LSej1's Avatar
yeah the IC piping is another issue...i may have to buy a U off ebay or something rather than the one i have now....i think that would make up for the difference. the turbo is just about not touching the block... as long as i can get it to not touch i wont be concerned...that way it wont wear a hole anywhere...
I have a inlinepro 5 bolt DP i could use...so really all i would have to buy is a new 5 bolt exhaust housing for the turbo right?
Old May 5, 2010 | 07:24 AM
kyden's Avatar
not really. downpipes match your turbo and manifold combo.
whats wrong with the turbo placement right now? it looks like it fits okay now.
Old May 5, 2010 | 07:29 AM
LSej1's Avatar
the compressor housing/block are about 1/16th of an inch apart...i can BARELY fit a piece of paper beteen them
Old May 5, 2010 | 07:45 AM
kyden's Avatar
thats fine. its not really gonna move...
Old May 5, 2010 | 07:46 AM
th3pwn3r's Avatar
Good luck on whatever you decide to do. You'll get it done eventually.
Old May 5, 2010 | 07:54 AM
dpetro1's Avatar
this should work too. i used a revhard manifold with inlinepro dp, fit perfect.
Old May 5, 2010 | 08:11 AM
TheShodan's Avatar
Moderator
You would basically purchase a 5 bolt turbine housing that fits a stage III wheel, contitue to grind the block, and allow fitment. This has been done this way for years.
Or. Keep grinding, and have a downpipe made to fit that compressor.
Old May 5, 2010 | 08:50 AM
E85B18's Avatar
I think you're making this more of an issue than it needs to be. Why spend all the money on new turbos or piping? Just buy a spacer to extend the manifold off the block. Here is my revhard manifold with a Garrett GT3076. This is the only pic i have but you can see the spacer. If you need more pics I can take them when I get home.
Old May 5, 2010 | 09:03 AM
fast2camciv's Avatar
if its not even touching the block, i dont see the problem here? the motor and the turbo/manifold will all move together so that space will never increase/decrease. if it worries you, grind the block a bit for more clearance. its been done that way for many many many years now.
Old May 5, 2010 | 10:09 AM
30psi_gst's Avatar
Have your tried clocking either of the housing? When i put a turbo kit on i loosen those up, put the kit on and then tighten them when i know everything will fit. Make sure you mock up the downpipe before you tighten them, lower ic piping, oil feed and drain, everything before you tighten, it will save you some time.
The kit should fit, especially with just a T04E housing. Those turbos arent that big.
Old May 6, 2010 | 04:23 AM
LSej1's Avatar
there isnt a problem now...i have clearance...and yes i realize it has been done this way for years....but this was a lot of grinding to the point i was getting curious about going through the block and exposing the flywheel....
Old May 6, 2010 | 06:44 AM
dpetro1's Avatar
the housing isnt very big but the way the manifold is designed causes the clearance issues. 5-bolt turbo housings have a slighly different design giving better clearance.
OP, glad you got it to work. i would be nervous too having to grind that much off the block
Old Nov 10, 2010 | 01:52 PM
da9ops's Avatar
what bolts where used to mount the turbo to the manifold,i just bought a rev hard turbo manifold and can't find any studs to mount the turbo!
Old Nov 10, 2010 | 04:07 PM
ShanghaiOC's Avatar
On your intercooler piping, get a bandsaw & cut a section off of the pipe coming from the turbo. Just put another silicon section with clamps on it...call it a day!
Fc_v8
Sep 21, 2010 01:01 PM
BOOSTEDgs-R
Feb 18, 2008 09:47 PM
Big_S
Feb 6, 2007 08:17 PM
xpracing
Feb 7, 2003 02:26 AM
chris@cfranklins
Jan 1, 2003 04:35 PM
