hf manifold...need help with turbo
Old May 1, 2010 | 10:31 AM
knightsef-eg's Avatar
Default hf manifold...need help with turbo
well i just swapped a d16y8 into a 97 ek hatch and its running good
i traded my b series flywheel for a for hf manifold i took it to work and cleaned it up .. i planning on running 5-7 lbs of boost but not sure what turbo to use.
im going to order a bmcrace.com hf adapter plate ... what turbo would be good and should i run external or internal waste gate ..
thanks guys iv been searching but cant seem to find a good one
Old May 1, 2010 | 10:47 AM
Gunmetal_B20_Hatch's Avatar
Default Re: hf manifold...need help with turbo
You are limited to an internal WG unless you bore a hole into your manifold... LOL.
What is your budget for the turbo?
Old May 1, 2010 | 11:38 AM
dont really have one lol i work at a welding shop with a plasma and linkin power mig
Old May 2, 2010 | 12:32 PM
any other info?
Old May 2, 2010 | 01:18 PM
was looking at a Garrett Turbo T3 t04e .60trim with .63A/R
Old May 2, 2010 | 02:36 PM
dpetro1's Avatar
are you referring to a 60 trim compressor wheel with a .63 a/r turbine?? if so i think that is too big and normally doesnt come internally gated. maybe you are confusing a .60 a/r compressor with a 60 trim?
a better fit might be a straight t3 super 60 or a gt28r/rs/71r (any combo of that turbo really)
Old May 2, 2010 | 07:48 PM
CivicSpoon's Avatar
Figure out your power goals, figure out how soon you want the turbo to spool, and do some research on how to read turbo compressor maps. Find some maps of internally gated turbos. Then pick the one that fits closest to your needs. Also check out what other people are using for similar setups, and then check out the compressor maps for those turbos.
sohctodohc
Sep 1, 2006 11:07 AM
mateencrx91
Feb 26, 2004 06:15 PM
racinskittle
Apr 10, 2003 09:27 PM
95IntegraGSRAZ
Apr 23, 2002 07:56 PM
