Turbo civic runs good in warm tempatures and bad in cold
Old Apr 30, 2010 | 11:08 AM
zach1288's Avatar
Default Turbo civic runs good in warm tempatures and bad in cold
I just started to notice this problem last night. During the day it has been in the 70's and the car runs fine full boost through all the gears. Last night when it got cold out(40-50) the car started to have problems. I have never noticed this before. Even throughout winter this was never a problem. I can hold full boost until around 6k and then it starts "cutting out" for seconds at a time but otherwise holds full boost. I'm not sure how to describe it. Its like a "hesitation". Do you have any ideas what is causing this?
My setup is:
Greddy TD04
Tial 35mm external on 9psi
D16y7 with y8 intake manifold
If you need more info please ask.
Thanks,
Zach
Old Apr 30, 2010 | 11:10 AM
azandford's Avatar
Default Re: Turbo civic runs good in warm tempatures and bad in cold
has it just been tuned or retuned recently?
my retard buddies street tuned when it was warm outside and now when its cold it runs like crap...
Old Apr 30, 2010 | 11:15 AM
zach1288's Avatar
It has not been tuned since last year.
Old Apr 30, 2010 | 11:23 AM
keving85's Avatar
Check your plugs. Denser cold air might be just to much for the gap.
Old Apr 30, 2010 | 01:45 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
what size gap do you suggest in colder temps for his setup?
Old Apr 30, 2010 | 03:09 PM
keving85's Avatar
I run 7re ngk's at .028". How many miles do u have on your plugs.
Just make sure that your plugs are not out of spec and check condition
kev
Old May 2, 2010 | 08:11 AM
zach1288's Avatar
kev
I changed my plugs maybe 4k ago. I can't remember the specs.
Old May 2, 2010 | 09:36 AM
danp1uk's Avatar
a car will run slightly more boost in cooler weather, what you are experiencing is more than likely overboost, i had a car that did exactly the same until i lowered the boost slightly, then it was fine
Old May 2, 2010 | 10:11 AM
Spawne32's Avatar
this is the exact reason why an A/F guage is an important tool
Mr.Death
Jun 10, 2009 09:21 PM
2000GSRT
Jan 20, 2005 10:31 AM
done
Dec 12, 2004 07:20 PM
djkermie
Oct 27, 2002 01:49 PM
