d16y7 turbo build
Old Apr 28, 2010 | 02:24 AM
jkalex05's Avatar
Default d16y7 turbo build
I am interested in doing a sohc non vtec turbo build. Id like to also do a stroker kit and build up the top end.
What do you all suggest for a stroker kit, cam, valesprings, retainers. Im thinking a T3/T4 Turbo setup would do nice.
Old Apr 28, 2010 | 03:09 AM
azandford's Avatar
Default Re: d16y7 turbo build
whats power are you lookin for hp wise?
supertech valvespring and retainers
if your goal is around 250-300 go with T3 60-1
also pick up the y8 manifold
Old Apr 28, 2010 | 03:26 AM
jkalex05's Avatar
My goal is 300hp
Im gonna get a y8 or ex manifold, what do you recommend for cam and bottom end?
Old Apr 28, 2010 | 03:34 AM
jkalex05's Avatar
Im gonna have to search around I can only find parts for D16Y6 will it fit the y7?
azandford's Avatar
zex or crower make great cams
im a now a believer in building the bottom end theres nothing better than a bit of insurance forged piston (JE, CP, WISECO ) and rods ( EAGLE FTW ) mild port and polish on the head maybe oversized valves if you want more power in the future
Old Apr 28, 2010 | 03:36 AM
jkalex05's Avatar
I am going to rebuild the whole motor and get forged pistons and rods, friend is gonna port and polish my head throttle body when I get the right intake manifold.
Old Apr 28, 2010 | 05:24 AM
Schister66's Avatar
Man U FTW
No offense, but that is a terrible turbo suggestion. If he was looking for 450-500whp, then maybe it'd be ok, but for a ~300whp D series, that turbo is lag city.
OP: I know you're looking in the 300whp range for your goal. I hope you plan to build the bottom end because the stock block D series is only safe to about 220-240whp...beyond that and you'll need to at least build a Vitara/Eagle setup to sustain the additional power.
I suggest you check out the Forced Induction forum as the Civic forum is chalk full of misinformation. Read the FAQ in FI and if you have further questions, ask them in the FI Forum...not here
Old Apr 28, 2010 | 06:04 AM
azandford's Avatar
my mistake... i though that turbo was good for about 300-350
Sorry
Old Apr 28, 2010 | 06:46 AM
jkalex05's Avatar
Im looking at some YCP Vitara 75mm bore pistons and Eagle Rods, ARP bolts, gaskets, main bearings, rod bearings, thrust washers, new timing belt, probably gonna get a skunk2 tuner cam gear, some 550cc injectors, T3/T4 Hybrid T04E Turbo, Walboro Fuel Pump, Mishimoto Intercooler & Radiator oh and some ZEX turbo spark plugs =D
Still not sure on how im gonna do my top end yet.
Still not sure how im gonna get it tuned.
Old Apr 28, 2010 | 08:03 AM
knightsef-eg's Avatar
i would recommend the eagles h-beams and vitaras i have a set and you cant go wrong with them in a d-series .. get a good set of super-tech valves and retainers.. over sized for more power if you crank up the boost ...
i wouldent worry about a stroker kit invest that money into a good turbo.. ramhorn mani etc
a good ecu and lots of DYNO tuning ...
don't forget to upgrade the clutch/flywheel when your in there .
hypeonline
Aug 19, 2012 09:14 AM
zcrx2006
Mar 28, 2009 11:08 AM
Frost7177
Apr 23, 2008 12:06 AM
CRX_Phantom1
Mar 16, 2006 03:23 PM
chippy
Dec 2, 2004 02:20 PM
