FUEL INJECTORS WON'T FIT!!
Old Apr 27, 2010 | 07:25 AM
Freshdot's Avatar
Default FUEL INJECTORS WON'T FIT!!
sup everyone, I have a greddy turbo kit for an integra LS motor that i'm slapping on my D16Z6..to my knowledge all if not most honda injectors are the same size. but these damn RC's the kit came with are giving me a hard time on the intake manifold side and the tops seat beautifully in the fuel rail. I read that they were going to be a tight fit as the RC's have a larger casing but this seems almost impossible..are there any tips for getting these suckers in? PS i'm a real novice and this is the first major install i'm doing on the car, so if there's a way to skill the injectors in the manifold i don't know what it is..i tried WD40 and engine oil so far.
thanx in advance!
Old Apr 27, 2010 | 09:01 AM
98integralsB18's Avatar
Default Re: FUEL INJECTORS WON'T FIT!!
push the injectors into the manifold push them in as far as you can and then put your fuel rail on and tighten it down
Old Apr 28, 2010 | 08:18 AM
Freshdot's Avatar
i've done this and there is a decent size gap between the O ring and the casing of the injector..is it ok to run them like this?
thanx for the help dude, i'm really scratching my head over here.
Old Apr 28, 2010 | 02:01 PM
Adam_b16a's Avatar
No you cannot run them like that.
Old Apr 28, 2010 | 02:30 PM
sanman000719's Avatar
do they leak?
Old Apr 28, 2010 | 02:32 PM
Sordz's Avatar
take the intake manifold off and get a round file and open the hole on the intake alittle so they fit. I had to do this with my h22 and pte1200's.
Old Apr 28, 2010 | 02:36 PM
nowtype's Avatar
Don't do this.
Do this. I'll add one thing that you want to EVENLY and SLOWLY torque down the fuel rail. You can even grease the injectors a little bit, but it's not really necessary.
Old Apr 28, 2010 | 02:41 PM
i started using lock tight on my fuel rail because there is nothing like being at the track coming off the line, and the fuel rail vibrating lose causing a fuel leak lol.
Old May 1, 2010 | 07:12 AM
Freshdot's Avatar
so I put the O rings in the plenum, mounted the inectors in the fuel rail..seated all 4 into the O rings and bolted down the rail..they seat nicely with the beginning of the casing pretty much on top of the O rings and not so much in them..i turned on the ignition, didn't start the car and no leaks..so i'm assuming eveything is cool.....so far, haha!
Cmy4gD
Mar 28, 2009 06:07 PM
b20ek
Jun 29, 2003 06:51 PM
aemciv
Mar 24, 2003 11:34 PM
Jamison
Jul 9, 2002 05:08 PM
