97 coupe with jdm b18c swap unsteady idle look
Old Apr 26, 2010 | 02:20 PM
donvito#1's Avatar
Default 97 coupe with jdm b18c swap unsteady idle look
so i got a 97 coupe with a jdm b18c swap using the y8 harness with a jdm p72 obd2a ecu skunk2 stage one cams with sk2 cam gears and a sk2 manifold and a bbk throttle body my issue is my idle is weird
wheni first got the car it was idleing at 1500 so i adjusted the throtle adjuster and got her to idle at 800 rpm so i started it again today and it was back at idleing at 1500 so i turned it off it sat for a hr and turned it back on and the idle was at 900 then turned it off sat another hr turned it back on and it idle at 1200 everytime i start the car it idle at a different rpm and it a steady idle, no surging or nothing like that all plugs are correct im thinking it my tps???
Old Apr 26, 2010 | 04:23 PM
donvito#1's Avatar
Default Re: 97 coupe with jdm b18c swap unsteady idle look
up
Old Apr 26, 2010 | 04:35 PM
Former User's Avatar
Clean the IACV and throttle body, and adjust the throttle cable to have about 1/2" of free play.
Old Apr 26, 2010 | 10:14 PM
donvito#1's Avatar
throttle body new iacv is clean and their no tension on the throttle cable
Old Apr 27, 2010 | 04:20 AM
Any CEL codes? Vacuum or intake air leak?
Old Apr 27, 2010 | 07:13 AM
donvito#1's Avatar
cel for secondary o2 bbut that because it not hooked up and no leak i think it the tps that the only thing that make since
Powered By Garrett
Oct 11, 2010 05:11 PM
gsrEGcoupe
Nov 15, 2008 12:51 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
StreetRacinThug
Mar 11, 2006 09:14 AM
Na99Si
Apr 3, 2003 02:59 PM
