Ignition timing problem
Old Apr 25, 2010 | 01:08 PM
Jorsher's Avatar
Default Ignition timing problem
Mechanical timing is perfect, I checked it while the engine was out the car.
Vacuum lines are all where they were the first time I drove it and the timing was fine.
It idles around 500rpm and should be at about 750-1000rpm.
If I give it gas and let off, it doesn't always catch itself and usually dies.
Distributor is turned all the way towards the front of the car (advanced?) and still isn't enough.
Yes I'm trying to set it with the service connector jumped.
It is a B18B block with B18C5 head.
Old Apr 25, 2010 | 03:05 PM
Jorsher's Avatar
Default Re: Ignition timing problem
Anyone?
Old Apr 26, 2010 | 07:57 AM
Jorsher's Avatar
Bring the tech!
Old Apr 26, 2010 | 08:02 AM
ChokolAwt's Avatar
you can adjust the idle with the screw by the throttle body.
how far off is the timing?
Old Apr 26, 2010 | 08:18 AM
Jorsher's Avatar
Well the idle improves as the timing gets closer to where it should be. If I could get the ignition timing where it should be, I think it would idle just fine. The timing is about 12-16 degrees too advanced, I'd guess.
Old Apr 26, 2010 | 08:38 AM
97twodoor's Avatar
If the ignition timing is out that much, then you need to retard your cams. Triple check your mechanical timing. What distributor are you using?
Old Apr 26, 2010 | 08:49 AM
Jorsher's Avatar
Head - B18C5
Block - B18B
Cams - B18C1
Cam gears - PR3
Water pump - 22T
Distributor - TD68U (OBD1 GSR)
Wouldn't retarding the cams cause performance loss? or no?
jeckel7234
Honda CR-V & Element
Mar 6, 2016 07:02 AM
bopbop93030
Feb 24, 2009 02:57 PM
LSTEG96
Sep 12, 2005 12:40 PM
handa
Apr 11, 2005 10:36 AM
RTW DC2R
Mar 9, 2004 09:09 AM
