Swapped LS into eg problem ( help )
Old Apr 24, 2010 | 08:36 AM
eghatchfla's Avatar
Default Swapped LS into eg problem ( help )
Ok i just got done swapping a 96 b18b1 out of an integra into my 1992 civic cx. It is running off of a po6.
It will start but barely run and sputter, after i rev it past 3k it clears up. same as in gear, is it because its running too lean from the po6?
im new to this, please help
Old Apr 24, 2010 | 08:55 AM
nsxter's Avatar
Default Re: Swapped LS into eg problem ( help )
probably a timing issue
Old Apr 24, 2010 | 09:00 AM
eghatchfla's Avatar
the motor ran perfect before i pulled it from the teg, i dont think its timing
Old Apr 24, 2010 | 09:12 AM
Gunmetal_B20_Hatch's Avatar
why in the hell would you try and run an LS off of a P06???
get the right fcking ECU.
Old Apr 24, 2010 | 09:15 AM
Mr. Winky's Avatar
^ correct ^
Get yourself a P75 or Obd1 Pr4
Old Apr 24, 2010 | 09:50 AM
eghatchfla's Avatar
because its whats was in my hatch before..
can i put the plug into the obd1 harness pr what???
Old Apr 24, 2010 | 09:56 AM
xero_xero's Avatar
the cx has an economy tune for a high mpg rating. you can swap for a dx ecu, but an odb1 p75 would be optimal. all odb1 ecus have the same plug in. if you want odb0 you will need a jumper harness.
Old Apr 24, 2010 | 10:04 AM
eghatchfla's Avatar
alright ill have to see if i can find another obd1 ecu..
i think the ecu off the teg is a p75 but obd2, ill check and write back
Old Apr 24, 2010 | 10:19 AM
miguel329's Avatar
yea get ls ecu.
99ej6gsr
Jun 11, 2009 10:22 PM
Ricextacy
Nov 22, 2008 05:40 AM
eg6boii
11
Aug 31, 2008 09:05 PM
