VSS Code
I just finished putting an 04 motor in an 02 Rsx Type S. Everything runs mint. And I mean the motor is quiet, strong, no knocks, absolutley perfect. We had idle problems but swapped throttl bodies and it idles fine now. Then the VSScodes came on so we swapped the sensors from the 02 block into the 04 block. The sensors from the 04 block were differnt looking and have different part numbers. But it was running fine, and the VSS code was cleared and stayed away. Today, for the first time I pushed the car past 6200 Rpms and Vtec engaged and sounded solid. So I got home shut the car off, when I turned it back on, the CEL was on and it was reading the VSS code and the car wouldn't go past 6000 Rpms and now it does go past 6k Rpms but no Vtec. BTW, when the sensors from the 04 were in, it was doing the same thing. Do I need to reflash the engine to 04 specs, or will the ECU take care of this issue by itself?
Do I need to reset the '02 ECU? With '04 specs?
WakeSpliter
Apr 4, 2004 11:06 PM
