B18b1 trouble!?! Im stumped
Old Apr 21, 2010 | 05:06 PM
UndisputedH22a's Avatar
Default B18b1 trouble!?! Im stumped
Alright i just swapped a B18b1 into my 98 civic hatch, Used my stock cx harness and just repined one plug and extended two wires,and now i got the car running its strong as hell. There is just one problem,I changed out 3 diff Ls distributors and none of them would start the car, so i put my d16y7 distributor on the motor and well guess what fired right up. Ok thats fine for now the cars, now the problem that i am having that i cant figure out is the car is bucking and bogging before 2700Rpm after that no problems...What could be causing this issue,the single cam distributor wont let the car idle below 1500rpm as far as that car runs good pulls pretty hard for an ls....Please someone tell me what the reason is for the car acting like that before 3000rpm's
Old Apr 21, 2010 | 05:11 PM
RICKSAUTOMOTIVE's Avatar
Default Re: B18b1 trouble!?! Im stumped
hows the fast idle valve? could be thats what is keeping the idle up...bogging before 2700...i would check the fuel pressure through the rpms up to like 4000 assuming it does this at idle too. start there
Old Apr 21, 2010 | 05:53 PM
it putters a lil at the 1500 idle but gets bad up till 3000rpm im also using the single cam injectors if that means anything
Old Apr 22, 2010 | 08:12 AM
bump for more opinions
Old Apr 22, 2010 | 01:02 PM
bump ttt
Old Apr 22, 2010 | 05:31 PM
bump whats the fast idle valve???
Old May 3, 2010 | 01:44 PM
If i got an OBD1 ls ecu and did the obd2 to obd1 conversion would that eliminate my code 54????
Old May 3, 2010 | 03:35 PM
b20hatchek's Avatar
why didnt you say you had a cel, whats code 54 i dont wanna look it up, and what ecu are you useing?
B18b Axles
Jul 16, 2013 05:55 AM
mikeycivic
Jun 22, 2010 01:59 PM
V.T.E.C.
Aug 4, 2008 06:13 PM
Jr.915
Feb 7, 2005 03:53 PM
Jr.915
Feb 6, 2005 07:58 PM
