98 GSR into 92 civic hatch CX
I got a little problem with my wire harness. I can't distinguish what harness i have. From what i have seen and looked up, my 98 harness should have two plug connector for the distributer. I only have One. Also, the distributor that is on the motor as well only has a one one plug connector. It all connects fine. The problem i am havin is that i have no spark. the book tells me to change the icm. can n e one please help!!!!!!!!!!!!!!!!
P.S. Im running a JDM P73 with an adapter harness...
Re: 98 GSR into 92 civic hatch CX (Jr.915)
ok now your stock harness on the car now will have 2 connectors one with a bunch of wires and one with only two i believe you want to convert the stock harness to work with the engine not the other way around by a conversion harness from someone here on honda-tech
Re: 98 GSR into 92 civic hatch CX (primeredbeast)
wait you got me all wrong... the engine i have came with that harness.... That engine has a distributor with a one plug connector, the harness is the same it also only has one plug.... all of the other gsr's that i've seen for that year have a two plug distributor, therefore in not sure if this is the correct distributor/harness for the 98 b18c1 motor that i have..
how can i figure out what the hell this harness came out of.. also, how do i fined out what this distributor this is from?
