oil feed line question...
Old Apr 20, 2010 | 03:34 PM
Dre90's Avatar
Default oil feed line question...
I've been researching trying to learn how to basically install the oil lines on a turbo and I believe I just about understand...EXCEPT I was curious when you run the oil feed line down to the oil pan...how does the oil reach into the oil inlet of the turbo???
Old Apr 20, 2010 | 03:42 PM
k20rex's Avatar
Default Re: oil feed line question...
put a tee in the back of the block at the oil pressure switch i think you can use a 1/8npt bass tee fitting for feed and run a return line into the upper part of the oil pan
Old Apr 20, 2010 | 04:11 PM
Dre90's Avatar
Oh okay thanks man...
gabe768
May 22, 2010 01:18 PM
Gtimportfanatic
Oct 31, 2007 09:06 PM
killamike0001
Sep 6, 2007 12:22 PM
MikeMAN
Jul 2, 2002 09:25 PM
AutoboTxEK
Nov 29, 2001 12:16 PM
