air/fuel gauge stays on when car is off
Old Apr 17, 2010 | 03:05 PM
castle1313's Avatar
Default air/fuel gauge stays on when car is off
so i noticed today when i turn my car off the air/fuel ratio gauge stays on when. when its running it doesn't read like it should its all over the place, when i shut it off the light goes all the way rich and stays on. also when i move my power mirrors around the light will jump all around even when the cars off. does anyone have an idea to what could cause this or were i should start?
Old Apr 17, 2010 | 04:10 PM
94VTEC2TONE's Avatar
Default Re: air/fuel gauge stays on when car is off
where did u hook power 2
Old Apr 17, 2010 | 04:37 PM
skracer13's Avatar
Is this a Wide Band or narrow? The power is on constantly because you have the power wired to a constant instead of a switch +12 or you have a short.
Old Apr 17, 2010 | 06:44 PM
castle1313's Avatar
its not wired to constant power, it always shut off before
Old Apr 17, 2010 | 08:28 PM
Spawne32's Avatar
if it doesnt turn off...its getting power somewhere, so break out your test light and start testing the connections to see what has power after you turn the key off and go from there.
Old Apr 18, 2010 | 01:48 AM
castle1313's Avatar
been multimetering it all night and i cant figure it out. i know more than the average person about electrical, took a class in high school, but its never done this before, and theres not a short. maybe im missing somthing but its weird just took my car out for a spin and it worked fine. shut off now but we'll see in the morn.
Old Apr 18, 2010 | 02:01 AM
NACvicSi's Avatar
Plain and simple you have it wired to a constant or it's a short. Some little fairy didn't break into your car in the middle of the night and wire it up to a mystical invisible battery.
Also unless you are running it connected to a wide-band all you have is a retarded light show.
Old Apr 19, 2010 | 06:14 PM
obviously u dont know more than the average person cause you been multimetering all nite. remove its power source and see if it has power. possiblity u have short to power on a circuit next to it cause wiring could have got messed up. but i have an aem wideband and i doubt that happened. maybe somethings not powering down. then again u arent telling us what u have this run to. hmm maybe u should
Natural Aspirations
Engine Management and Tuning
Sep 6, 2012 05:27 AM
folta2169
Apr 17, 2005 01:03 PM
CharmCity
Dec 4, 2003 07:30 AM
greekspeed
Apr 11, 2003 05:58 AM
FuzzyGreen
Feb 26, 2002 12:14 PM
