JDM front end question
Old Apr 17, 2010 | 10:09 AM
MilFhunter001's Avatar
Default JDM front end question
I'm moving to Texas and they require all corners to have turn signals. As it is right now my front corners are only running lights.
I need a dual element light socket so it can be a running and turn signal.
Does anyone know the part number of a socket that will fit properly?.
Thanks in advance
Justin
Old Apr 17, 2010 | 07:20 PM
94rs-turbo's Avatar
Default Re: JDM front end question
i can try and find the parts or #'s for you but I hope you have blinkers even now when you drive lol what part of TX will you be moving to?
Old Apr 18, 2010 | 09:27 AM
The fronts are only running lights and i have the side markers as blinkers.
To Fort worth
Old Apr 19, 2010 | 11:42 AM
Tekkaboy's Avatar
You can file down the tabs on the USDM turn signal bulb socket to make it fit.
Old Apr 19, 2010 | 02:51 PM
Dr. DC2's Avatar
you barely have to file them down. its not hard to do at all GL
Old Apr 21, 2010 | 11:20 PM
Well i went to the wrecking yard in search of some sockets instead of trying to buy them from the stealership. I came across a Daewoo lanos, or whatever the hell it is. It had the two contacts in its turn signal sockets. Since everything that was Honda the headlights and wiring was ripped out.
I used the socket from the JDM headlight to compare the two.They looked like they would work so i bought them.
After wiring everything up and installing them they work perfect. So i now have running and turn signals simultaneously, courtesy of a P.O.S DAEWOO.
Old Apr 22, 2010 | 08:13 AM
Dr. DC2's Avatar
You just got killed by a Daewoo Lanos ***** fuka!
Old Apr 22, 2010 | 03:17 PM
94rs-turbo's Avatar
Oh Mr. Folgers.......
You think yous gonna get me? ***** fuka!
EastLAdrian
Feb 19, 2011 08:35 AM
Stevegunit16
Jul 5, 2008 07:03 PM
miravete
May 23, 2007 11:19 AM
BOOSTED_JDM_DB8
Oct 28, 2005 06:32 PM
BlingBlingCivic
10
Sep 7, 2001 12:42 PM
