headlight question...
Old May 21, 2007 | 02:21 PM
miravete's Avatar
Default headlight question...
ok, this is for the jdm headlights, not the usdm.
when you turn on your parking lights, which ones are the ones that have to turn on? for what i know, its the ones on the fenders, the corner ones, and the little bulb in the high beams section, right?
low beams/high beams, and the yellow ones should be off.
and also, should the yellow ones blink when you put your turn signals?
thanks for the help guys.
Old May 21, 2007 | 02:57 PM
Ohgodzirra's Avatar
Default Re: headlight question... (miravete)
fenders should only illuminate when signalling, as they are a supliment to the signalling system, not the fog lights.
Old May 22, 2007 | 05:29 AM
Padawan's Avatar
Darth ModerVader
I am assuming you're asking about how the lights would function on a JDM Integra. If so, with the first click only the city lights (the small bulbs in the high beams) will be illuminated. The markers in the fenders and the corner lamps are only used as turn signals or hazard lights.
The "yellow ones" are the fog lamps.
Old May 22, 2007 | 01:17 PM
miravete's Avatar
Default Re: headlight question... (Padawan)
ok ok. thanks for the help
Old May 23, 2007 | 11:07 AM
JDM_EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">I am assuming you're asking about how the lights would function on a JDM Integra. If so, with the first click only the city lights (the small bulbs in the high beams) will be illuminated. The markers in the fenders and the corner lamps are only used as turn signals or hazard lights.
The "yellow ones" are the fog lamps. </TD></TR></TABLE>
Correct. That's how i have mine wired. OEM
Old May 23, 2007 | 11:19 AM
Bradstard's Avatar
Yep
NorthernXposure
Aug 11, 2006 02:11 AM
MikeyDB7
Mar 5, 2003 02:43 PM
uNF$@#!
Apr 21, 2002 03:57 AM
SKRacer
Dec 25, 2001 02:14 PM
