LS Vtec questions...
Old Apr 15, 2010 | 11:01 AM
Lzonk's Avatar
Default LS Vtec questions...
me and my girlfriends dad are building an ls vtec motor. were using a '99 B16 head and a '97 ls block. the old guy timed the motor to a gsr head and ls block specs. does it make a huge difference or it is ok as long as the points a straight up and the crank is lined with the points on the block? also if anyone has done this same set up and u help me with a hose diagram for the IM and etc.
Old Apr 15, 2010 | 01:07 PM
mouab18c1's Avatar
Default Re: LS Vtec questions...
If I can remember right all stock B series have the same timing set at 16 degrees with a timing gun.
Old Apr 15, 2010 | 07:32 PM
Lzonk's Avatar
ok cool. do u know how the vacuum lines connect because now its spewing oil and i cant figure out where a few connect... anybody got a suggestion?
Old Apr 15, 2010 | 07:43 PM
mouab18c1's Avatar
Uhh oil should not be shooting out from your vacuum lines. If it is then somethings not right.
Old Apr 15, 2010 | 07:50 PM
Lzonk's Avatar
ya i got it fixed. something isnt right with the vacuum lines because its not running right. i acts like its bogging out. i have a b16 head/ ls block... u know of any place i can find a vacuum diagram for that set-up? i think i got it but its still running weird
Old Apr 15, 2010 | 07:55 PM
mouab18c1's Avatar
Try googling it. And make sure that their isnt any vacuum leaks. A picture would help
carlossolorzano
Oct 31, 2010 02:08 PM
Tong.Y
Dec 7, 2009 10:02 PM
oksblue
Sep 15, 2009 08:02 PM
PHiZ
Jan 28, 2004 08:44 PM
