integra has jumpy rpm needle and stalls
Old Apr 14, 2010 | 06:08 PM
elmejor's Avatar
Default integra has jumpy rpm needle and stalls
hi i have an 94 ls that i recently did a b20b swap...but my car has a problem at when i first turn my car on it started fine and about 5 minutes after driving it i noticed that my rpm needle was jumpy and my car would stall..so at first i thought it was my throttle body cause i had the tps sensor code i replaced the throttle body and car was fine for like 10 min and the problem started again..the next day i changed the igniter and coil from the dizzy that came with the b20 and car was fine drove the car all day and had no problems until the next day the same problem started happening again and my car stalled and would not star.. car started up like 3 hours after that and i drove the car and it was fine then i got the jumpy rpm needle and car stalled. it happens random my car would stall and work fine again after a couple of hours... i used my friends dizzy and car still had the same problem..also i forgot to mension that when i crank it i get smoke coming from my throttle body.. need help can this be a bad ground, an ecu problem????
Old Apr 15, 2010 | 04:19 AM
elmejor's Avatar
Default Re: integra has jumpy rpm needle and stalls
I've lsearch this and based on what I read it seems to always be the igniter, but I used my friends good dizzy and it still gives me this problem....help would be appreciated
Old Aug 1, 2010 | 11:48 AM
StRacer's Avatar
I have the same issue now, except the jumpy needle. Mine runs for about 10 mins then dies. I replaced cap rotor plugs and wires. I even changed the coil and it did it still. Ever get a fix for this?
Old Aug 1, 2010 | 01:58 PM
redflaredcrx90's Avatar
make you sur you dont have any cut or loose wires
Old Aug 1, 2010 | 04:02 PM
StRacer's Avatar
in my distributor the negitive connection internally some wire was exposed, but i covered it and it is fine from what I can tell. It wasnt cut or nothing, just little of the insulative material was off.
Old Sep 7, 2010 | 01:58 PM
kingjames0509's Avatar
i had same problem it was the main relay definitly
Old Sep 8, 2010 | 11:43 AM
Black01gsr's Avatar
My buddy has this problem. He said his was wiring.
Old Sep 8, 2010 | 02:58 PM
Jimmy's Avatar
Global Moderator
I had a similar issue with my integra when I first bought it, Jumpy needle right before the ICM failed. The service manual says to trace the wires down from the distributor and check for exposed/loose wires.
I believe there is also information on this in the [faq] thread i stickied at the top of the forum
LinkATX
Jul 14, 2009 06:33 PM
M2B4
Jun 28, 2008 07:32 AM
lamsv
Aug 21, 2006 09:46 PM
Kaji
Aug 25, 2005 09:48 PM
