h22 no power
Old Apr 12, 2010 | 07:12 PM
g-dan90's Avatar
Default h22 no power
im havin problems with my car it has like no power i floored it and only got to like 80 in like a miles distance really need help give me a call if you have any idea what it might be 6825513130 or message please
Old Apr 13, 2010 | 09:43 AM
jkoni426's Avatar
Default Re: h22 no power
i would do a compression test, or a tuneup if it's been awhile
Old Apr 13, 2010 | 06:55 PM
gstrudler's Avatar
A little more info is needed... like mileage, mods, last service done, any symptoms, any CEL's, what gear you are trying this in.
"Help me help you"
Old Apr 17, 2010 | 07:30 PM
g-dan90's Avatar
it is in every gear i got a skunk 2 pro series manifold head was rebuilt 3000 miles ago got cold air intake all the way exhaust runnin a virgin p13 ecu a f22 wiring harness with some h22 conectors rewired them
Old Apr 17, 2010 | 07:54 PM
Rockstar21's Avatar
damn, you should be at 80 before a 1/4 mile.. that thing must be crawling...
how was it running before the head was rebuilt... have you consulted with the shop/person that did the work yet?
Old Apr 17, 2010 | 09:39 PM
g-dan90's Avatar
hell should be hittin in aLMOST 1/8 MILE it ran fine but ran fine aftert just started goin downhill from there
Old Apr 17, 2010 | 10:11 PM
Import RP's Avatar
Have a compression and leakdown test performed. That should be your first starting point to see the health of your engine.
Old Apr 17, 2010 | 10:40 PM
88luda's Avatar
Check all your vacuum hoses to make sure you don't have any leaks, make sure they are all going to the right places and are fitted tightly
Old Apr 18, 2010 | 01:12 PM
cobaltsrt4's Avatar
your car could not have enough compression or a vacuum could be loose
Old Apr 18, 2010 | 01:17 PM
g-dan90's Avatar
any one wanna help me out im broke though
yungmulacrx
May 11, 2012 09:42 PM
purekoryo
Feb 16, 2007 07:11 PM
RotiEatter
May 16, 2005 04:09 PM
