how much work to put VTEC sohc motor on non-vtec block
Old Sep 10, 2002 | 08:54 AM
2000_Civic_Si's Avatar
Default how much work to put VTEC sohc motor on non-vtec block
i'm not lookin for life here cuz i have a b16 sittin in my room but i just wanna see how much i can get out of the sohc for the hell of it, i know i would probably need Headgasket, and is there any way to make vtec work without a vtec ECU
Old Sep 10, 2002 | 08:55 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: how much work to put VTEC sohc motor on non-vtec block (2000_Civic_Si)
Sorry man, but I have a hard time understanding your topic title and the message contained within.
Old Sep 10, 2002 | 09:01 AM
hondafrk's Avatar
Default Re: how much work to put VTEC sohc motor on non-vtec block (B18C5-EH2)
I believe that he is referring to a Mini-me setup. A z6 or y8 head on a non vtec block. You can get the vtec to activate with a rpm activated switch if you dont have a vtec ecu.
Old Sep 10, 2002 | 09:03 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: how much work to put VTEC sohc motor on non-vtec block (hondafrk)
RPM-activated switches are only good for VTEC, but what about the fuel and timing issues?
The correct ECU will run the motor correctly. Just buy the correct ECU and don't half-*** it with an RPM switch. There really is a difference, but I suppose if you come across a really cheap RPM switch and you're just bored, try it.
...It won't run 100% though.
Old Sep 10, 2002 | 09:28 AM
Plan B's Avatar
Or install a switch and turn vtec on when ever you want
vtechaccord
Mar 14, 2011 03:03 PM
regal1975
13
Apr 13, 2007 06:00 PM
HatchEh2
10
Jun 3, 2006 09:37 AM
hOndafienD 04
Jan 1, 2005 02:13 PM
eg6madness
Mar 5, 2003 07:52 AM
