vtec/oil problem
Old Apr 10, 2010 | 02:54 PM
cadeMFjohnson's Avatar
Default vtec/oil problem
i was doing some turbo maintenance, and i hooked everything back up, but tired from work and tired from working on my car after work, i accidently left the oil feed line to the turbo off. i idled down the driveway and turned around and my CEL light came on so i killed the car and popped the hood. found the problem. i hooked it up and added oil and the car is running fine but CEL still on!!! damn thing. code 22, vtec pressure switch. i bypassed my pressure switch over a year ago. my turbo oil feed line comes from where the switch used to be. what could be wrong here? car runs fine but no vtec obviously.
Old Apr 10, 2010 | 03:00 PM
98civdx's Avatar
Master Detailer
Default Re: vtec/oil problem
unhook the battery to clear the ecu and see if it comes back.
Old Apr 10, 2010 | 03:22 PM
was in the process of resetting via ecu fuse and i just installed it and success. thanks
Old Apr 10, 2010 | 04:48 PM
nevermind. i drove for a few minutes and the problem reoccured.
Old Apr 10, 2010 | 06:28 PM
redid the splice where i bypassed. will drive later and ask again if its still bad, right now its not coming on idling for fifteen minutes or so
Old Apr 10, 2010 | 06:52 PM
brent eg's Avatar
i need help my vtec quit working and have no idea why i re wired from the ecu and still nothing any ideas throwing codes 6 and 21
bakomack
Aug 17, 2010 12:22 PM
jdm-as-f@$k
18
Jul 10, 2010 09:11 PM
mister2racer
Jun 26, 2005 07:13 PM
hierohed
May 27, 2005 10:17 AM
punkassazn
Oct 1, 2004 12:13 PM
