Calipers do not fit on with new pads and rotor
Old Apr 10, 2010 | 11:22 AM
Bad Brian's Avatar
From: Japanese Domestic Mutt, aka JDM, Conn., U.S.A.
Default Calipers do not fit on with new pads and rotor
The title says it, I can not get the caliper into position. 98 Civic EX sedan
Rebuilt calipers, new rotors and pads. From Advance Auto.
The rotors do mic. out a bit thicker but the same thing actually happened when I bought the outgoing rotors a couple of years ago. Back then I checked out other types of pads but they were all too thick so I got around the problem running one older pad with a new one on each side for about 9 months, then I swapped in the other mismatched pairs for another season, by then I had worn down the "new" ones enough to fit in together.
Has anyone had this happen? Solution? Cut the new rotors. That will cost almost what I paid for the new ones,LOL.
Also, I got Wearever Silver pads. The set does not have any wear tabs. All 4 pads are the same. Can that be right?
Old Apr 10, 2010 | 01:05 PM
john666's Avatar
Default Re: Calipers do not fit on with new pads and rotor
im guessing u got cheap-e pads and cheap-e rotors.. could always just grind/file down the pads a bit. thats if the caliper piston is pushed in all the way and it still doesn't fit.
Old Apr 10, 2010 | 01:09 PM
98civdx's Avatar
Master Detailer
are you sure you pushing the piston all the way?
Old Apr 10, 2010 | 03:05 PM
POLLO's Avatar
^^^ What he said ^^^
Old Apr 10, 2010 | 06:32 PM
TurboTron's Avatar
i had the same problem a while back...i just sanded a bunch of the new pads off until it all went together....no big deal
Old Apr 10, 2010 | 07:34 PM
300whpej's Avatar
wait a minute, when is sanding new brake pads/rotors ever a good idea? either the brake caliper wasnt compressed far enough with a c-clamp, or you have the wrong pads.
Old Apr 10, 2010 | 08:26 PM
Bad Brian's Avatar
The pistons are all the way in on these rebuilt calipers. That would be the first answer but it is not the problem. The casting is not wide enough to take the pads and rotor! But the same thing happened a few years ago when the original rotor went bad and I got 2 bendix replacements plus pads to replace the original Honda pads and the car still had original calipers. That is when I mismatched new with old as mentioned above. That time I compared different types of pads. I even took back Wagners to another place because I though they were the problem but every brand had too much stock on it.
This time they are Wearever rotors and pads.
This is the 2nd time in 3 years that I have had this problem. Somebody must have run into this before.
Has anybody seen a set of pads come without warning tabs on the inboard pad?
Old Apr 10, 2010 | 09:24 PM
300whpej's Avatar
i used to run the cheap-o valucraft pads from autozone and never had a problem. no problem getting my hawks to fit either
Old Apr 10, 2010 | 09:39 PM
Unseen Racer's Avatar
i have the same problem. and before any1 tells me to push the piston back, ITS NOT THE SIDE OF THE PISTON!!
i repeat, ITS NOT THE PISTON SIDE!!!!
for me, its the side that faces the outside. the outer side.
Old Apr 10, 2010 | 10:36 PM
David12's Avatar
did you check your part numbers to be positive that they didn't give you the wrong parts? happens ALL the time
Old Apr 10, 2010 | 10:38 PM
speedooo's Avatar
yeah seriously advance auto kept gave me the wrong axle 5 times in one day, and the wrong brakes twice on another occasion
Old Apr 10, 2010 | 10:42 PM
David12's Avatar
^ that's what they are known for
Old Apr 10, 2010 | 10:59 PM
slomofo's Avatar
GDD Member
This happens frequently, I hate that ****.
Old Apr 10, 2010 | 11:14 PM
Bad Brian's Avatar
Yes on correct pad and rotor #s, I have the boxes. Cant be sure on the calipers as the cores went to Advance in them. The calipers fit the brackets fine and the old and new hardware match up. I wonder if the calipers are narrower for DX, LX, etc. for some reason but they are entirely different part #s anyway, and not what I have in hand. Like I said, last time this happened the Wagner pads were just as beefy, I had gotten them at a regional chain.
I guess you need to buy "REAL" Honda parts and go broke to eliminate problems. Then again, the dealer hands out Prestolite wires and Tec dist. caps to replace my Honda stuff. Tec was aftermarket when I bought it from the old Motomart, it is OEM at the dealer now.
Old Apr 10, 2010 | 11:16 PM
Bad Brian's Avatar
I saw a post with photos on this subject the other day, the axles looked about 3 inches different in length!
Old Apr 10, 2010 | 11:24 PM
b18cKoupe's Avatar
yup, axles are the number one problem in my experience with advanced and autozone.
Just last week they also gave me a bad alternator right out of the box, checked it out with the service manual and it was a bad voltage regulator after I installed the whole thing. Waste of time and then they look at you like your a moron, second new alternator fixed the car. What if I had to pay a mechanic twice for that ****? your beat, money out of your pocket.
Old Apr 11, 2010 | 12:28 AM
speedooo's Avatar
Yeah they ****ed my stepmom on an alternator once...it literally almost lit the car on fire. The plastic ring around stud for the cable was missing...mechanic cranked it down and the car almost caught on fire on the way home. Another time I bought an alt there for my eg and the pulley was too small so it squeaked constantly. I returned that **** and they gave me cash+refunded my credit card. I made $186 on that deal LOL
I went in there for 97 civic ex front rotors and was given dx rotors....twice.
They gave me the wrong hub bearing once, considering almost all 88-00 and 90-01 civics/integras use the same bearing that took talent.
I asked for 98 gsr axles for a b series swap in my eg...they kept giving me da axles and d series axles. I gave up and went to NAPA after 3 days of aggrivation. I asked for 99-00 si axles and was given the correct **** on the first try. Advance has different part numbers for ls/gs/rs, gsr, si and del sol vtec axles. wtf lol
Old Apr 11, 2010 | 07:25 AM
DX and LX rotors and calipers are smaller than the Ex ones. so if they gave you
Dx or Lx brake pads, they wont even fit in the caliper. and the pads i got
are too beefy as well. still gotta go return them
Old Apr 11, 2010 | 08:57 AM
siboosted's Avatar
i just used advance auto parts rotors and pads on my hatch with gsr front brakes and didnt have an issue.
Old Apr 11, 2010 | 09:02 AM
speedooo's Avatar
I also didnt have an issue...once i made a third trip and was guaranteed the correct parts.
OP just go back there and tell them the **** doesnt fit and you want your money back...then go to another store. If that doesnt work then take the caliper back and hit the salesman in the head with it
Old Apr 16, 2010 | 05:43 AM
munky69's Avatar
i had this issue when i upgraded my calipers.. i had to take the clips of and grind down the tab on the back of the pad. no problems after that. but you prob got a dx/lx mix up is my guess
Old Apr 17, 2010 | 03:05 AM
novaksaotome's Avatar
some times the caliper doesn't slide enough in the axles, in other words the bolts that attach the caliper to the arm are seized and wont let the caliper slide as far as it is supossed, then you encounter the problem of the pads being too thick. probably the axles of the new calipers are not seized pob the wrong size...
Old Apr 17, 2010 | 01:37 PM
ok. i figured it out. when you remove the caliper, there will be 2 12mm bolts ON the caliper itself. losen those 2 bolts and the outer side of the caliper will slide out a bit more. which will make the brake pad fit perfectly. i did it and it slipped right in
Old May 14, 2021 | 08:29 PM
Chaos Juggalo's Avatar
So I have similar problem I bought calipers from powerstop for my 97 civic ex coupe and the outside inner tightens up to rotor when I tighten the bolts and than rotor wont spin. Can anyone help with this
Bad Brian
Suspension & Brakes
Sep 19, 2008 08:04 AM
thinknology
Apr 6, 2005 07:11 AM
flip1199
Oct 24, 2004 06:12 AM
mr tl
Sep 20, 2002 08:22 PM
Flux
May 29, 2002 07:26 PM
