Shifted From 5th to 2nd
My friend called me tonight telling me he was about to race someone (he has 2001 prelude)and he was about to downshift from 5th to 4th, but it somehow he went into 2nd. His RPM's dropped to zero and he pulled over and turned off his car. Then when he went to start it back up, it wouldnt start. So he had it towed to Honda. Anyone know what may have happened?He says he probably bent some valves....
Thanx in advance.
Thanx in advance.
agrees, bent valves. o yea he may fired some piston rings depending on how high the RPMs jumped. "now me and the mad scientist got to tear apart the block and replace the piston rings u fried" hahahahahaah
updated version form one of are very own HT members "now me and ronald got to tear down the counter and replace the onion rings u fried"
rev limiter will protect you from makeing it that high in a gear, but mechaniclly if you go into the wrong gear, the car is moving so its going to moove the enging to match the speed.
i went from 8000 in 3rd , to second the day i tightend my valves, soo bye bye valves! it looks as if its only the exust ones, but im not totally sure yet.
Thanx in advance.
Thanx in advance.
*Has flash backs and runs out of the post screaming*
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
sounds a little familiar..
I just took my head to the machine shop yesterday... All my exhaust valves were bent.
/sigh
/sigh
yeah, i have a 96 prelude si (h23) anyways i was cruising down the road one day and got in a little race, shifting from 5th to 2nd accidently, anyways all that happened was my tach maxed out and quit moving and my power steering belt shot off... guess i was lucky!
He just got his car back from the shop a few days ago after someone doing a hit and run, In which he payed $1000 that i had to borrow from his gf. Today Honda caled and said it's going to be $1200 to just inspect it. He doesnt have that kind of money... WHat to do.
for honda for high prices). any "good" perofrmance shop should be able to replace the valves and they will be way cheapers than honda. and if he needs to save even more money tell him to take the head off and put it back on himself, only let the shop install the valves.
B_Swapped93
K Series
Feb 6, 2017 09:19 AM
