NEED HELP! D16 88CRX TURBO
Tryingto install a turbo in but having trouble figuring out where i can input the oil return hose into the block. Been looking around the internet and kept on noticing people saying there is a port hole already to be accessed next to the oil filter. Have looked but no luck.
Thanks for looking and giving any advice.
oil feed is the line on top of the turbo (small hole) which runs to the back of the block to either the small hole where the oil temp sensor is and run a a fitting there or run the line to an oil sandwich to the oil filter.
the oil return would be the bigger hole at the bottom of the turbo that would go to the oil pan that needs a bung to be welded on.
for the feed line i recommend a remote tee fitting like this
http://www.xenocron.com/remote-oil-p...kit-p-329.html
takes a lot of stress off the block
15psi of fun
Feb 4, 2003 10:17 PM
