96 honda accord
Old Apr 6, 2010 | 12:05 PM
oreostylez's Avatar
Default 96 honda accord
I am new to the Honda scene. I have a 1996 Honda Accord sedan with a sohc f22 and a five speed manual. i just got a 22 psi Audi TT turbo and i want to know what i need to do to be able to run that turbo. Any ideas?
Old Apr 6, 2010 | 01:53 PM
ilikehonda's Avatar
Default Re: 96 honda accord
well not sure what the 22 psi bs means but anyway.
manifold, intercooler, piping, down pipe, oil lines, engine management (aem, hondata, crome, uberdata etc), blow off valve, wastegate, couplers, etc etc etc use the search button
Old Apr 7, 2010 | 12:46 PM
oreostylez's Avatar
what about internals? pistons, rings, crank? i still want to keep it a daily driver
Old Apr 7, 2010 | 01:56 PM
ilikehonda's Avatar
you can run 250-280 whp stock daily. Pistons and rods will allow you to run quite a bit more hp on a stock block. the stock crank will be fine.
Old Apr 7, 2010 | 02:26 PM
Targa250R's Avatar
be professional
Uh, what?
You have a lot of reading to do.
Old Apr 8, 2010 | 12:58 PM
oreostylez's Avatar
i do have a lot of reading and research to do. i have only ever done repairs and maintenence before. this will be the first car i have ever tried to build up which is why i ask for pointers and ideas on what i need to look into.
Old Apr 8, 2010 | 06:13 PM
uberEFtuner's Avatar
Most likely you will have to make a custom adapters to make that downpipe fit. So good luck.
96f22b1
Sep 5, 2018 12:38 PM
fljmruiz
Jun 23, 2017 06:23 PM
Cogar23
May 23, 2017 10:49 PM
F22Boost
Aug 23, 2015 12:16 AM
WyattEarp
Jul 29, 2011 01:25 PM
