SiR parts into a DX hatch
Old Apr 3, 2010 | 07:04 PM
Momentum's Avatar
Default SiR parts into a DX hatch
Picked up an sir with smashed front end for the motor and parts and have a few questions.
I swapped the sir cluster, what are the green and orange plugs for? My dx cluster doesnt have them.
Will sir door panels fit onto the hatchback? How hard is it to convert to power windows and door locks?
How difficult would the rear disk swap be to do?
Would the rear seats swap over?
What else is there that i can swap thats worth doing?
Old Apr 3, 2010 | 07:55 PM
98civdx's Avatar
Master Detailer
Default Re: SiR parts into a DX hatch
by chance was your car a auto at one point?
all coupe and hatch door pannels are the same: and switch the whole door with harness, shouldnt be to hard,
rear disk- simple, shouldnt take to long at all.
I think the dashes may be differnt? seats, front disk breaks plus sway bars, (cant wait to put mine on)
Old Apr 4, 2010 | 08:07 AM
Momentum's Avatar
Pretty sure it was never an auto.
Also since i swapped clusters and the rpm's are different on them, will my rpms/mileage still be accurate?
Old Apr 4, 2010 | 10:24 AM
98civdx's Avatar
Master Detailer
yes, all 96-00 civic culsters are plug and play, just noticed your in canada that may explain it
Old Apr 4, 2010 | 05:56 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
I started a lengthy response, but more info required: is the SIR a Canadian 99-00 car or is it a JDM import? What year is your car?
FYI for now: Orange plugs are usually for ABS stuff.
Pics please!
Old Apr 5, 2010 | 05:40 PM
Momentum's Avatar
My car is a 2000 Canadian DX.
Parts car is a 2000 Canadian SiR.
Im really wanting to do the door panel swap for the power windows and locks and rear disk swap, but electrical and brakes arent really my thing aha.
I paid $300 bucks for anything i want off the SiR minus the engine. So far all i have taken is the cluster, center console/armrest piece and passenger seat.
Old Apr 5, 2010 | 05:46 PM
TurboTron's Avatar
your car should still have all the harnesses run...you just did not have the instuments in your dx....should be plug and play
Old Apr 5, 2010 | 05:49 PM
TurboTron's Avatar
$300 for whatever you want? I have an SiR and would love that deal...go to town on that thing...power mirrors...heated mirrors...all the seats....rear brakes.....front LCA's just in case you do a motor swap in the future....
Old Apr 5, 2010 | 06:54 PM
Momentum's Avatar
Are you serious i would already have the wiring for the doors i would just need to plug in a harness?
And will the rear sits fit into my hatch?
Old Apr 6, 2010 | 01:14 AM
JizzleCX's Avatar
Is your DX a coupe or hatch? If it's a coupe yes they will fit, not in a hatch tho.
Grabd the front and rear brakes (front brakes are bigger on the SiR) the prop valve/master cylinder/brake booster, mirrors, doors, front and rear sway bars and control arms (your model doesn't have the points to connect sway bars to) strip that bad boy down, you can sell what you dont use!
Old Apr 6, 2010 | 05:44 AM
TurboTron's Avatar
make them fit...can't be too far off...he he....unload that SiR!! I may need some parts from you in the future
I'm not sure about the harnesses in the doors...could be there....I just know that the cluster wires will all be there.
Old Apr 6, 2010 | 09:31 AM
Momentum's Avatar
I just read on another forum that the ex model has the wiring harness for the doors. The dx only has speaker wires going to the doors so i will have to swap the floor harness (under the carpet) and all the wiring. Cant be too hard to do. I will try to tackle this sometime soon.
I will have to look up a write-up for the brake swap. But it is also something i would like to get done soon.
Old Apr 26, 2010 | 09:22 PM
Momentum's Avatar
Actually the DX Hatches have the holes for the sway bars in the rear lca's, i will check to see if they have the holes in the fronts, i am not too sure about that.
Does anyone know if i swap JUST the rear brakes from the SiR onto my DX Hatch, will ALL the parts i need be on the SiR? Or will i need to get e-brake cables, MC, Prop Valve from another car? Thanks.
Old Apr 26, 2010 | 10:05 PM
deschlong's Avatar
Loved
Community Favorite
Here's a little read-up on brake swaps: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/definative-brake-upgrade-guide-bolt-brake-upgrades-%9292-%96-00-civics-2645527/, should answer a few of your Q's.
Other things you can swap: leather shift **** + boot, all cruise control parts (that's what the green cluster plug is for), leather-wrapped steering wheel, heated mirrors + all that other power crap that was mentioned (you might just want to swap the ENTIRE cabin harness), what about rims?, front SiR grille?,
ThaiRacer
Aug 28, 2012 03:52 AM
ThaiRacer
Aug 27, 2012 12:39 PM
TheRealJDM
Dec 1, 2008 03:23 AM
phatboi
Mar 22, 2005 05:53 PM
IS3Fifty
Feb 27, 2003 02:18 PM
