Hesitation on accelaration
1997 Honda civic 4 door EX. 145k miles. I have recently cleaned and cleared all the fuel lines, did a full tune up. But it is still acting up.
Last night was real bad. Prior to last night it was intermitent and not easy to reproduce. The rpms will bounce around. It never revs faster always drops. It isnt an electrical power loss. I have a feeling it is possibly the transmission, but have no idea what would cause it.
Usually the transmission will cause the RPMs to rev higher and trigger a check engine light with a trouble code for different shaft speeds from a slipping clutch pack. I would check the ignition system. Have you checked the distributor cap, rotor, etc?
itsmike
Jul 25, 2004 06:59 PM
