Which wire do I tap into for signal for a ricer tach??
Old Apr 2, 2010 | 12:33 PM
Arthas's Avatar
Default Which wire do I tap into for signal for a ricer tach??
Sup all, installing a 52mm tach in a friends car and I need to know which wire do I tap into for the RPMs??
I already got the ground and power but now I just need the signal on the distributor or cluster to tell me the RPM's.
Thanks!!
Old Apr 2, 2010 | 01:52 PM
DoubleEx's Avatar
Default Re: Which wire do I tap into for signal for a ricer tach??
check the computer diagram for rpm sensor.
Old Apr 2, 2010 | 02:06 PM
Gunmetal_B20_Hatch's Avatar
what a shitty post...
It would help if you supplied year/make/model.
Old Apr 2, 2010 | 02:12 PM
mortificationrock's Avatar
Thanks!!
Well as far as diagram for cluster i have no idea, but i can give you the easy choice wire.
Tap into the blue wire with connector at the shock tower on drivers side. There is 1 plug with 1 wire. Thats the one HONDA uses to check rpm idle etc. You cant miss is. Its the only one plug covered in some sort of boot. By the clutch reservoir.
Old Apr 2, 2010 | 05:54 PM
canadaek's Avatar
first i agree. go to bulldogsecurity.com and look up the car in the wireing diagrams then look for tach signal on the instructions remote starters use a tach signal also
Old Apr 11, 2010 | 11:57 AM
Arthas's Avatar
Ahh yes I know that plug!
In case anyone wants to know, I just rubbed the wire across the cluster harness plugs till the tach 'moved', then I soldered it to that one. It works like a CHAMP.
civiclxb16a
Apr 30, 2005 09:37 PM
joecivic93
Jan 6, 2004 10:07 PM
bluebomb
Jul 21, 2003 12:20 PM
civicracer1993
Sep 17, 2002 10:53 PM
CheezeFrog
Jul 19, 2001 07:57 AM
