another vtec not engaging thread
Old Apr 1, 2010 | 06:05 PM
accord2civic2prelude's Avatar
Default another vtec not engaging thread
here is my problem. im running a sohc v mini me...b7 w/z6 head. vtec is wired up correctly but vtec isnt engaging. when i hit vtec, around 46 or 47, my CEL lights up and stays on. when i turn the car off to check it, the cel stays solid and my srs light blinks. i am really confused right now. the ecu works, tried it on my other car. any suggestions? compression is 190 across the board and oil pressure is decent.
Old Apr 1, 2010 | 06:08 PM
builthatch's Avatar
MiG-21 superfan
Default Re: another vtec not engaging thread
what's the code?
Old Apr 1, 2010 | 08:41 PM
thats the thing, no code is blinked. The srs light flashes at a steady pace and the cel stays light, which means there is no code..right? i even tried jumping it will the car was still on but the cel went off for a second then came back on solid and the srs flashed.
Old Apr 1, 2010 | 08:46 PM
ReVeNgEd-SoN's Avatar
There is no procedure given to display and Read Diagnostic Trouble Codes without a scan tool so you will need to let the honda dealer to extract the Diagnostic Trouble Codes (DTC) for the Supplemental Restraint System (SRS)
Old Apr 1, 2010 | 09:04 PM
the srs blinks at a constant pace while the cel stays solid. if the srs blinked in random strokes, then yes.
when the srs blinks and cel is solid, that means one of two things: 1. there aren't any codes or 2. the ecu is fried.
i tried the ecu (chipped p28) in my 94 h22 and it worked great, vtec engaged.
with the cel coming on when vtec is supposed to hit, what could it be? i cleaned the gasket and vtec housing, changed the solenoid to a known working one and still nothing.
Old Apr 1, 2010 | 09:11 PM
builthatch's Avatar
MiG-21 superfan
hmm. i'm suspecting wiring issues - i can't think of what else it could be, especially if you tried the ECU elsewhere and it checked out. though i don't know why the SRS light would come on too.
i'm curious now too, lol.
Old Apr 1, 2010 | 10:00 PM
it only comes on when i jumped the service connector. one thing that i thought it could be was that i spliced a4 and d6 together due to the oil pressure sensor like i had it on my first 94 mini me(same motor). before i did that, vtec wouldnt engage also, but the cel wouldnt come on.
Old Apr 1, 2010 | 11:41 PM
bump
Old Apr 2, 2010 | 03:26 AM
anybody?
Old Apr 2, 2010 | 07:01 AM
bump
Old Apr 2, 2010 | 04:26 PM
bump
seth01tuner
Mar 25, 2012 12:28 AM
Apr 2, 2010 07:01 AM
jeezyskillz
Feb 1, 2007 07:06 PM
nosegrindR
Apr 19, 2006 11:28 AM
ninety9ex
Jan 26, 2004 07:40 PM
