GSR Shredding JRSC Belt under load...
Old Apr 1, 2010 | 08:34 AM
Green94GSR's Avatar
Default GSR Shredding JRSC Belt under load...
Sold my JRSC GSR to a friend and now it is shredding the super charger belt when he puts his foot in it. Says he can drive around for a weeks without stepping on it and the belt is fine, but as soon as he drives it hard the belt tries to walk off the pulley. It was fine for the five years I had the car with the JRSC. Started after he broke the alternator drive belt. What would cause this? Any ideas?
Old Apr 1, 2010 | 10:45 AM
R.A.T.'s Avatar
Default Re: GSR Shredding JRSC Belt under load...
Nose pulley and stepper pulley not aligned correctly.
A few washers should do the trick.
Most probably the alternator pulley is off, so just put some washers behind it to align it with the nose pulley.
Old Apr 1, 2010 | 11:30 AM
Green94GSR's Avatar
Could the belt breaking have caused this pulley misalignment? Bent the alternator bracket? Something he did when trying to change the belt? I appreciate the help, thanks.
Old Apr 1, 2010 | 01:31 PM
Gold DA9's Avatar
most of the time its from the pulley not being lined up.
Old Apr 1, 2010 | 04:22 PM
miguel329's Avatar
yup^ what he said same **** happen to my friend
Old Apr 2, 2010 | 11:53 AM
Green94GSR's Avatar
Thanks, i'll help him check pulley alignment. Maybe he just left a bolt loose on the alternator bracket or something.
Old Apr 2, 2010 | 04:19 PM
Blue-Civic-Hybrid's Avatar
Loved
Icon6 Re: GSR Shredding JRSC Belt under load...
Pulley alignment is the culprit. Check the pulley near the alternator and the alternator itself.
Has your friend changed any of the pulleys yet? If you sold him a used kit, his best bet is to probably buy new pulleys, belts, and re-align everything.
Old Apr 2, 2010 | 08:01 PM
nextproject97's Avatar
well since I am such a computer guru lol I cant fiqure out how to copy and paste the info but if you go to the "what jackson racing supercharger are you running " thread and go to page 117 post #2923 there are pics and info that should help you
Old Apr 2, 2010 | 10:00 PM
I CRX I's Avatar
here you go my friend
https://honda-tech.com/forums/showth...14810&page=117
its the third post from the bottom.
Old Apr 3, 2010 | 03:36 PM
Green94GSR's Avatar
Thanks guys. Checked it out today and it looks like when he replaced the idler pulley he somehow got it shimmed out to far from the bracket and it is forcing the sc belt off the nose pulley. I told him to get that aligned, and if that doesn't work start shimming other pulleys. Appreciate all the responses and I'll post the results.
end005
Aug 31, 2010 06:42 PM
vactor
Mar 8, 2007 02:20 PM
92TEGsrSC
Jan 1, 2004 07:26 PM
illi Adik
May 14, 2003 12:39 PM
dariusz
Jan 29, 2002 05:52 AM
