problem with ebay fogs
Old Mar 31, 2010 | 07:41 PM
senorkree's Avatar
Default problem with ebay fogs
there is an extra brown male connector that has a fuse on the same wire. the switch has power to it because the light turns on. the relay clicks when I press the switch. the lights dont turn on...man im mad. I was thinking if it was better to just direct wire it. opinions?
Old Mar 31, 2010 | 07:47 PM
Trey's Avatar
25 Year Member
Default Re: problem with ebay fogs
Ground?
Old Mar 31, 2010 | 07:59 PM
burningrex's Avatar
that's what you get for buying ebay brand ****.. but good luck sorting things out
Old Mar 31, 2010 | 09:42 PM
josh89's Avatar
you know you have an eg when... haha.. every damn civic in america has those fog lights and none of them work or are even actually wired lol
Old Apr 1, 2010 | 06:38 AM
OliverV's Avatar
i don't know if i have ebay ones, but i sorted it out with a new relay and the fog switch i had in dash.. and i just had only the wires from the foglight bulbs.. so just try to use your head or google the wiring of some random foglights!!!
Old Apr 1, 2010 | 06:43 AM
z6hatchboy's Avatar
this might help, https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/egay-knock-off-fog-light-wiring-help-2716028/ . its a while since i done my ebay ones but i just searched on the net some
Old Apr 1, 2010 | 06:58 AM
TurboTron's Avatar
I have purchased like 4 pairs of those cheap fogs for my 99 and all of them wire right in and work just fine
Old Apr 1, 2010 | 07:19 AM
senorkree's Avatar
yeah well they were 20 bucks so it was kinda expected that they were all f ed up
yeah im thinking about just wiring direct i know the relay is messed up and the wiring is kinds faulty. oh well at least they look nice.haha
Old Apr 1, 2010 | 07:44 AM
JasonYo's Avatar
http://www.passwordjdm.com/Install_N...tall_Notes.pdf
This might help, it's what I used when I installed mine.
It was a while ago and I don't remember what wires went where really. Don't remember a brown plug.
Old Apr 1, 2010 | 07:59 AM
senorkree's Avatar
those looks like the honda instructions, which i did use. there is just this one last brown plug which i have no idea where to plug into. ill get some pics up in a bit.
Old Apr 1, 2010 | 08:03 AM
envybryce's Avatar
It is a ground
Old Apr 1, 2010 | 08:23 AM
senorkree's Avatar
where do you guys think the extra one goes?
Old Apr 1, 2010 | 09:02 AM
john666's Avatar
im guessing the other brown one goes to fuse box also. perhaps power for lights or etc.
Old Apr 1, 2010 | 09:06 AM
senorkree's Avatar
well that's what the first one is for. thanks anyway.
Old Apr 1, 2010 | 09:53 AM
LTCxD2B's Avatar
i have a setup similar to that but mine did not come with anything to the fuse box at all and they work by power from the battery and ground with a harness from each fog back up to the button to the switch on the steering column
Old Apr 1, 2010 | 09:56 AM
senorkree's Avatar
I was actually thinking about just doing something like that. I'm too damn frustrated to be dealing with this.haha
Old Apr 5, 2010 | 06:57 AM
senorkree's Avatar
turns out that there were 2 hot wires. -_-
Old Apr 5, 2010 | 09:01 PM
joel96sedan's Avatar
my ebay fogs arent working?! If i had a nickel. no offense but save and buy genuine parts. i learned my lesson years ago
Old Apr 5, 2010 | 09:07 PM
but are they working fine now? i bought ebay fogs in 06 and had extra wires too, but they still worked. well for like 8 months, then just stopped working, so i got better ones, and are great to this day
Old Apr 5, 2010 | 09:25 PM
Meoshe's Avatar
That plug DOES go into the fuse box as well. One goes to the BATT plug and the other goes to headlight switch one.
This guide seems to have the same wiring as you so follow this ---> http://www.clubcivic.com/board/showthread.php?t=66852
Old Apr 5, 2010 | 11:01 PM
thumper64's Avatar
I've heard if you add an extra, good ground and basically just rewire it all, they'll work, until the bulbs burn out...which won't be too long.
MGBej1503
Nov 8, 2011 11:42 AM
born2sleep13
15
Oct 26, 2011 06:40 AM
prox25
35
Oct 10, 2009 11:32 PM
Mr EG
11
Jan 8, 2009 01:07 PM
SinsEvil666
Nov 9, 2007 01:10 PM
